Forums >> Revit Building >> Technical Support >> Window not showing up correctly in wall?
Thu, Feb 7, 2008 at 10:31:33 AM | Window not showing up correctly in wall?
DevinB
I've inserted a window in a wall, and while it's showing up just fine in the Main Floor Plan, it's not working so well in the Furnishings Plan. I've joined the two walls using Join Geometry. The cut plane is set the same as the main floor plan. My visibility graphics are all set correctly as far as I can tell. What am I missing? Thanks for any help.
Devin
Thu, Feb 7, 2008 at 10:40:22 AM | Window not showing up correctly in wall?
DevinB
Sorry about the double posts. And I'll try to attach the picture again. Oh, and I'm using Revit Architecture 2008.
Windows not showing correctly in legend
Mon, Dec 14, 2009 at 5:22:42 PM
Door and Window Frames not showing in Elevation
Thu, Dec 17, 2015 at 4:34:06 AM
Exterior wall brick showing in window
Tue, Sep 7, 2010 at 12:59:13 PM
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:06 PM
New window not loading correctly?
Wed, Jan 14, 2009 at 2:48:14 PM
Page generation time: 8.6172
