Forums >> Revit Building >> Technical Support >> plan/section segmented cut line
Mon, Mar 7, 2005 at 2:31:09 PM | plan/section segmented cut line
aabrmn
Architects sometime take the freedom to draw plan views and sections using a variable cut line. Is this possible in Revit? Thanks. Post edited on 2005-03-07 14:32:14
Mon, Mar 7, 2005 at 5:19:31 PM | RE: plan/section segmented cut line
TomDorner
4.5 Stars: 25 Votes
In a plan view your can use " Plan Regions" to vary the cut line in a region of the plan. See the Revit help file for a decent explanation. Sections now can jog as well in 7.0 See the Revit help file for "segmented sections" Tom
Mon, Mar 7, 2005 at 7:12:24 PM | RE: plan/section segmented cut line
aabrmn
Tom, this is a great new. I will investigate this issue on the help. Thank you very much for all your help.
Segmented section cut
Wed, Oct 10, 2007 at 1:19:40 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Section Line in Extends Beyond Plan (2009)
Sun, Sep 21, 2008 at 11:30:18 AM
Curtain Wall Mullion Profile Does Not Display When Cut in a Segmented Section [ 1 2 ]
Fri, Sep 28, 2012 at 11:11:19 AM
15
Can see section marks cut on plan, and the ones I cut earlier in the day do show
Thu, Mar 2, 2017 at 1:20:00 PM
Page generation time: 1.4980
