Forums >> Revit Building >> Technical Support >> Spiral stairs that follow a conical wall
Mon, Feb 4, 2008 at 4:02:32 PM | Spiral stairs that follow a conical wall
asanders
Here's a doozy... I need to make stairs that follow the exterior of a conical (tapered) circular tower.  The base interior radius is 5.5' and the top interior radius is 4'.  The stairs need to be 3' wide.  My guess is that I will have to make an in-place model, as I don't think this is possible as a 'stair' model component. Either way, it seems like a huge pain in the rear. (RAC 200Shadey
 Any ideas?
Mon, Feb 4, 2008 at 4:14:57 PM | Spiral stairs that follow a conical wall
Should not be a problem  - I just modeled one that uses a series of tagent curves to approximate a spiral.
Mon, Feb 4, 2008 at 4:19:38 PM | Spiral stairs that follow a conical wall
asanders
ah i see.. that makes sense... so you just worked your way up and in, one stair at a time?
Mon, Feb 4, 2008 at 4:36:13 PM | Spiral stairs that follow a conical wall
You can do it one tread or more.  It's up to you.  It partly depends on if you want the same distace between each tread at the minimum side or if you want the treads spaced equal angle radially.  Th easy one is equal angle.  Just array some guide lines then use those along with a correct spiral.
Mon, Feb 4, 2008 at 4:46:33 PM | Spiral stairs that follow a conical wall
asanders
thanks!
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Railings for spiral stair is not following stair incline
Mon, May 20, 2019 at 8:36:25 PM
conical roof generation
Wed, Oct 25, 2006 at 6:58:28 AM
Joining a conical roof to a gable roof or other rectangular roof
Tue, May 28, 2013 at 9:29:25 AM
Spiral Stairs
Fri, Jul 4, 2008 at 1:34:57 AM
Page generation time: 2.1727
