21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Assemblies
6 Posts No Rating |
How does one make an assembly of a series of similar windows along an array to include the wall on either side if one was to frame the window in between structural columns that are built out with metal stud and sheet rock ( wall above on either side ). This would then be used to copy the assembly in between the other column spaces
You could try creating one sections as you want it to be then try grouping the assembly and copying into the other locations. This will hopefully mean any changes you make to the assembly should be reflected in all groups.
HTH.
copying assemblies between projects |
Fri, Jun 1, 2012 at 10:39:32 AM
Graphic display options assemblies |
Thu, Nov 21, 2024 at 3:35:02 PM
Assemblies |
Mon, Mar 18, 2013 at 5:46:04 PM
Groups & Assemblies |
Fri, Jan 27, 2012 at 12:07:38 PM
FLOOR ASSEMBLIES |
Sat, Feb 26, 2005 at 8:25:19 PM
