Forums >> Revit Building >> Technical Support >> Accurender texture
Fri, Feb 1, 2008 at 9:49:06 PM | Accurender texture
trhymans
I have a stone *.jpg I want to use on a stone.  I can't seem to find where I put to the file so accurender recognizes the file.  I found the rendering subdirectory but I can't get it to find it when I want to apply the texture to a material.
Mon, Feb 4, 2008 at 12:39:43 PM | Accurender texture
mthurnauer
3 Stars: 2 Votes
Open up the material window and create a new material.  Next click on the Accurender button on the right.  This will open up the material library.  In the middle field labeled 'Name', right-click and pick 'New'  and the 'Default Grey...'  This will open the matreial editor.  Click on the 'Maps' tab.  Below 'Image Mapping' click 'Add.  Browse and find your image map.  You wilkl then need to set the Tile Size, orientation, etc.
Help Changing Accurender bump map texture colour
Tue, Oct 19, 2004 at 6:29:51 PM
hardwood flooring accurender texture needed
Wed, Aug 10, 2005 at 1:08:15 PM
Faded white when rendering
Mon, Oct 23, 2006 at 8:43:12 PM
Tiling Seamless Texture Images
Tue, Oct 12, 2004 at 8:08:15 PM
Accurender situation
Fri, Mar 30, 2007 at 1:34:58 PM
Page generation time: 0.0388
