Forums >> Community >> Newbies >> HELP PLEASE
Fri, Feb 1, 2008 at 4:30:25 PM | HELP PLEASE
pancho
CAN ANYONE EXPLAIN TO ME CATEGORIES AND SUB-CATEGORIES
SPECIFICALLY SUB CATEGORIES: WHAT ARE THEY? AND HOW DO THEY FUNCTION?
Sat, Feb 2, 2008 at 6:33:18 AM | HELP PLEASE
MikeChan
3 Stars: 5 Votes
Categories are preseted organisation in every project in Revit, which represent all types of Revit components (Family) you can have. Except adjust the graphical appearance and visibilty, not much you can do with them.
Sub-categories are organisation of a category, they are partly preseted and some are from the components you loaded into the project, also you can add more sub-category under a category from time to time, if you need.
The function of Sub-categories are same as categories, which are used for adjust graphical appearance, visibility control and  organize the project.
Hope that helpful
Sun, Feb 3, 2008 at 4:58:17 AM | HELP PLEASE
4 Stars: 205 Votes
Look, the CATEGORIES are e.x.: "DOORS", "WINDOWS", ETC. and the SUB-CATEGORIES: "MULLIONS", "FRAMES", "GLASS", etc..., the sub-categories make part of a Categorie Family...
Mon, Feb 4, 2008 at 10:57:28 AM | HELP PLEASE
pancho
NOW THAT I KNOW THE BASICS HERES A NOTHER QUESTION
I HAVE TWO TYPES OF CASEWORK MOVABLE AND NON MOVABLE CAN I CREATE TWO SUB-CATEGORIES? ONE FOR THE MOVABLE AND ONE FOR THE NON SO THAT I CAN TURN OFF EITHER OR. I NEED TO BLE ABLE TO GIVE THE ARCHITECT THE ABILITY (FOR LACK OF BETTER TERMS)TO ISOLATE THE THE TWO TYPES.IF SO IT WOULD SOLVE MANY A PROBLEM. AND I FORGOT HOW DO YOU CREATE THE SUB CATEGORIES?
AND THANKS FOR THE RESPONSES
Mon, Feb 4, 2008 at 11:12:40 AM | HELP PLEASE
You can create sub-categories from within the model or a family.   Settings / object styles then pick the "Modify subcategory" new.
If you want this to work at the family level, you must create the sub category there.  Once you load a family with a new subcategory, that sub category will be loaded.
So the answer is yes, you can have movable and non-movable and cotrol them through VG.
Page generation time: 1.3015
