Forums >> Revit Building >> Technical Support >> Gaps shown in plan view when showing demo/existing
Fri, Feb 1, 2008 at 3:50:54 PM | Gaps shown in plan view when showing demo/existing
Jbajek
When I show demo and existing in plan view it shows a gap between the two walls.  But there is no gap in any other views. (just showing existing/3d views) Why does it do this?  What can I do to fix this?
Fri, Feb 1, 2008 at 4:28:21 PM | Gaps shown in plan view when showing demo/existing
lazarus512
Not sure how you created the two walls, but it might work if you create one wall, use the split tool and then demo your wall segment.  Hope that helps.
New Door Cuts in the Demo Plan
Wed, May 22, 2013 at 3:21:44 PM
Existing floor with a new stair opening... need help with phasing
Thu, Apr 25, 2013 at 11:10:34 AM
Objects showing in wrong plan view
Sun, Oct 10, 2021 at 8:10:49 AM
linework from existing to demo plans
Thu, Dec 1, 2005 at 8:32:01 AM
Phasing Setup
Tue, May 15, 2012 at 1:29:05 PM
11
Page generation time: 9.9288
