Forums >> Revit Building >> Technical Support >> Radial/ Polar Array.
Fri, Feb 1, 2008 at 11:46:43 AM | Radial/ Polar Array.
mflure
Greetings all,
Working on site content.  (Currently have Revit MEP 2008, but I have Revit Architecture 2008 in the mail).
 I'm trying to figure out how to set up a arc based family, if that is possible.  I've found out that in REVIT you cannot assign a parameter (or at least I can't) to a dimension for arch length.  The issues I was hoping to solve is that if I'm laying out a parking plan and the run is based on a arc then I could load this family up either pick a arc and it would automatically array the striping along the arch so that the minimum distance between striping is 8ft.  Since I don't have much experience with the creating of the more complex families I was hoping someone could tell me if its not possible, or if it is.. and if it is. how would I go about it.
 Thanks,
 Michael
Fri, Feb 1, 2008 at 2:19:21 PM | Radial/ Polar Array.
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You are correct about adding a lable to an arc dimension.
You could however, apply a lable to the arc degrees and it will act the same way, just a little extra thought to it.
HTH
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Feb 5, 2008 at 5:39:48 PM | Radial/ Polar Array.
mflure
I just hope the new version has this capability in it.. It would make life a whole lot simplier
Mike
Vertical Offset, Polar Array
Tue, Mar 21, 2017 at 3:04:39 PM
Polar Array - How to constrain the center location?
Tue, Nov 19, 2013 at 2:14:44 PM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:12 PM
Radial array in Families
Tue, May 28, 2013 at 3:04:01 AM
Is Solution to Creating a Parametric Polar Array?
Tue, Oct 22, 2013 at 8:40:06 PM
Page generation time: 0.0418
