Forums >> Revit Building >> Technical Support >> Missing Section of Wall to Roof
Thu, Jan 31, 2008 at 2:18:25 PM | Missing Section of Wall to Roof
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008. When I go to attach the top of the wall to the gable roof, I have a section of the wall that stops at the incorrect roof line. I need a wall to be in the section where it is missing (refer to image). How do I extend or create the wall to fill in the area where it is omitted. Again, I attached the other walls to the roof line.
Thu, Jan 31, 2008 at 3:11:12 PM | Missing Section of Wall to Roof
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
This is a common issue. There are a number of ways to fix it. My first suggestion would be to use the Edit Profile tool and adjust the edge of the wall to fill in the gap. You can also create the roof as 2 seperate roofs and use Join Geometry. A third option would be to create another wall from the roof level and attach it to the roof.
Roof Is missing a chunk
Mon, Nov 24, 2014 at 7:31:15 PM
Wall section marks not showing in roof plan
Thu, Jun 10, 2010 at 2:08:07 PM
Section callout missing
Mon, Dec 16, 2013 at 4:00:09 PM
Wall is not visible in section
Fri, May 13, 2011 at 11:11:02 AM
Create Wall Section Type
Thu, Jun 30, 2011 at 3:58:23 PM
Page generation time: 0.8599
