Forums >> Revit Building >> Technical Support >> Inserting backround photo into perspective view
Wed, Jan 30, 2008 at 6:01:05 PM | Inserting backround photo into perspective view
vnd
3 Stars: 2 Votes
Hi,
How do you insert a background photo into a perspecive view?
VND
Wed, Jan 30, 2008 at 7:28:12 PM | Inserting backround photo into perspective view
TRUEVISIONS
Its easy.. Select rendering tab. Then select settings. Then enviroment. Select background image. Once selected it goes to a select bitmap option (search computer for picture) . Once you find the picture you can adjust its location withen the view port. Say OK and OK....Thats it...
Hope I was a help...
TRUEVISIONS
JED
Thu, Jan 31, 2008 at 4:12:35 AM | Inserting backround photo into perspective view
vnd
3 Stars: 2 Votes
Hmmm... tried that, but the photo only appears when i do a raytrace... how do i get it to appear in normal model view so that i can stretch it to correct scale?
VND
Thu, Jan 31, 2008 at 1:12:38 PM | Inserting backround photo into perspective view
TRUEVISIONS
I am not possitive but I dont think that it is possible.. See if others know...Maybe ask Admin.
TrRUEVISIONS
Thu, Jan 31, 2008 at 1:23:10 PM | Inserting backround photo into perspective view
Aranya
I believe the best thing to do is insert the 3D image into a blank titleblock. Import the background image into the same sheet. Shift things around, apply the right visibility settings, and that should be the closest thing you can do w/ Raster images.
This is a very poor work around, but Revit is really weak w/ image manipulation.
--Aranya
Thu, Jan 31, 2008 at 4:44:52 PM | Inserting backround photo into perspective view
vnd
3 Stars: 2 Votes
I'll try the workaround, thanks Aranya...
VND
Plotting Photo-Realism
Fri, Nov 10, 2006 at 4:04:42 PM
Backround image [ 1 2 ]
Sun, Jul 27, 2008 at 7:12:50 AM
15
Moving Objects in 3d Perspective View
Wed, Jul 27, 2016 at 3:52:14 PM
perspective view
Thu, Feb 7, 2013 at 1:47:34 PM
matching photo settings
Fri, Dec 10, 2010 at 4:35:48 PM
Page generation time: 0.5552
