Forums >> Revit Building >> Technical Support >> What are people using window elevations?
Wed, Jan 30, 2008 at 5:36:43 PM | What are people using window elevations?
pixelpusher
 I was wondering what technique people are using to make Window Types sheets (also sometimes called 'window schedules' 'Or 'window elevations'.) From reading this forum and others, there seem to be 3 methods people are using:
1) Place windows into a Legend view:  Dimensions OK. Cannot be tagged. Cannot be cut w/ new details (ie detail views showing: jamb, header, etc ). Cannot show Curtainwalls. Minimal management.
2) Create Elevation views of each window: Dimensions OK. Can be tagged. Can host detail cuts.  Can show curtainwalls. Much more management keeping elevations in synch w/ windows as they move around. Must hide all window elevations come print time.
3) Create separate phase, and put window types in a wall. (phase happens after all other phases, and is hidden):Dimensions OK. Can be tagged. Can host detail cuts. Cannot show curtainwalls, unless duplicates are made. Less management of windows, but requires dealing w/ an additional phase.
So, which do you use? (My office is currently using method #2, but the management of the all the little window elevations is making the team cranky) If you use Method #1, how do you track the jamb and head details?
Are there other methods people are using besides those I've listed above?
(Revit 2008, build 0101_2345)
Edited on: Wed, Jan 30, 2008 at 5:37:26 PM
Thu, Jan 31, 2008 at 8:04:13 AM | What are people using window elevations?
JHanby
3.5 Stars: 3 Votes
We use method #1 for our window elevations and we also use a separate window schedule where we list the details for each window.
Thu, Jan 31, 2008 at 9:44:56 AM | What are people using window elevations?
NKramer
4 Stars: 9 Votes
We use method #2. You dont have to worry about hiding all of the elevations if you check the "Hide unreferenced view tags" in the Print Setup dialogue box.
The other option is to create a dupliacte type of elevation tag and use that for all of your window elevations. After you create all of your elevations then select one, select all instances, view properties, and change the hide at scales corser than. If you choose something crazy like 1:1 or 1/2" then you will never see them on your plot sheets. The down side of this is that you have to create a new view or change the scale of one of your views if you need to find/ modify them in the future.
Nick
New revit people for sections and elevations.
Fri, Oct 17, 2014 at 4:10:14 PM
how to add elevations to door & window schedules
Tue, Oct 30, 2007 at 11:59:24 AM
Window Elevations
Fri, May 18, 2007 at 5:18:02 PM
To Window Tag or not to Window Tag...?
Thu, May 21, 2009 at 12:33:24 PM
Where are the people?
Sat, Jun 21, 2008 at 6:19:09 AM
Page generation time: 0.8068
