Forums >> Revit Building >> Technical Support >> Wall Pattern lost in Existing phase
Wed, Jan 30, 2008 at 10:51:12 AM | Wall Pattern lost in Existing phase
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
We have a wall cut pattern set up for our new 1 hour rated walls that is a block void block style pattern.  Pattern works great for new walls, however when you change the walls to existing the pattern is lost.  I tried to overide by element and add the pattern back in in a gray tone to represent the existing rated walls, however when I do, the walls show as a solid gray poche and the pattern is lost.  Does anyone have an answer or work-around to get my existing rated walls to show with the same block void block pattern in gray for the existing phase?
Thank you
stanmpd
Belz A&C
Memphis, TN
Sat, Apr 12, 2008 at 11:14:05 PM | Wall Pattern lost in Existing phase
TesterSH
Hi "stanmpd"
I found the same problem with my fill pattern being changed when wall was changed to the "existing" phase.  I checked the properties of it and found that the "existing" phase overrides the visibility with the material called "Phase - Existing".  It seems that there is only one material for ALL existing entities and hence the grey.
Can anyone help?  It is sincerely appreciated.
Tue, May 27, 2008 at 2:08:45 PM | Wall Pattern lost in Existing phase
creid
Ran into this a couple weeks ago when beginning to use phasing for plan options. Right-click on the wall/object, choose select all instances, right click again and choose override graphics in view > By element... you can then change the profile & cut lines and patterns to match your existing poche/line weights.
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
New Construction phase cuts Existing Phase
Tue, Aug 9, 2011 at 12:21:57 PM
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
Wall surface pattern by phase?
Tue, Dec 8, 2009 at 11:49:08 PM
Existing wall cut by new wall even in existing view
Wed, Dec 13, 2017 at 1:11:12 PM
Page generation time: 3.4712
