Forums >> Revit Building >> Technical Support >> Revit Rendering - Why so dark?
Tue, Jan 29, 2008 at 2:33:00 PM | Revit Rendering - Why so dark?
dbtahoe
Every once in a while I attempt to render something but it always comes out so dark. What am I missing? I've tried all the tricks. Letting light through the window cutting holes in the ceiling.
Any help/tips would be greatly appreciated.
REV2008
Thanks
Tue, Jan 29, 2008 at 2:38:33 PM | Revit Rendering - Why so dark?
dbtahoe
It didn't upload my file
Tue, Jan 29, 2008 at 6:21:54 PM | Revit Rendering - Why so dark?
TRUEVISIONS
dbtahoe,
    Revit alows you to adjust you lighting (settings). It also alows you to make adjustments after the image has been generated. Select "Adjust Image", this then gives you Brightness,Contrast, and Indirect. Hope this helps..Let me know if I can be of any further help.
TRUEVISIONS
JED
Wed, Jan 30, 2008 at 10:02:19 AM | Revit Rendering - Why so dark?
mthurnauer
3 Stars: 2 Votes
Have you tried using radiosity?  Given the simplicity of your scene, it seems that it would be worth while.  Note that you would need to use the daylight tool under View>Rendering menu.  Pick the window or windows that will provide daylight.  Set up the light settings and radiate.  This will definitely improve your results.
Swimming Pool rendering with dark edges
Fri, Feb 22, 2013 at 7:49:38 AM
Revit Renderings too dark and take too long
Thu, Jan 7, 2016 at 8:15:51 PM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:19 PM
11
Interior Rendering is very Dark
Tue, Apr 30, 2013 at 2:30:55 PM
Interior Rendering Extremely Dark
Tue, Oct 26, 2010 at 3:35:27 AM
Page generation time: 7.4887
