Forums >> Revit Building >> Technical Support >> Slab Foundation
Tue, Jan 29, 2008 at 9:15:26 AM | Slab Foundation
rcobbjr
3.5 Stars: 3 Votes
I am trying to create a foundation wall for a slab foundation. The wall consists of 8" CMUs then there is 4" brick on top of the CMU. The CMU goes up from the footing about 2 to 3 feet. The CMU stops and the 4" brick veneer continues up for another 6" to 8". Looking on the top of the wall, you can see 4" of the CMU exposed that is not covered up by the brick. How do I create this foundation wall without drawing two walls on top of each other? See scanned image for better explaination of wall composition.
Tue, Jan 29, 2008 at 12:55:24 PM | Slab Foundation
TJKENNEDY
3 Stars: 2 Votes
You will need to create a stacked wall.
Thu, Jan 31, 2008 at 1:59:46 PM | Slab Foundation
rcobbjr
3.5 Stars: 3 Votes
This worked wonderfully....thanks
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
sloped foundation slab to flat slab join
Mon, Mar 25, 2013 at 8:01:59 AM
Mid slab foundation thickening
Tue, Jul 31, 2012 at 7:58:11 AM
Slab Foundation Questions
Fri, Mar 7, 2008 at 10:56:28 AM
Slab in foundation plan
Wed, Dec 21, 2005 at 5:10:28 PM
Page generation time: 0.1153
