Forums >> General Discussion >> Revit Project Management >> HELP! Callout modifications
Mon, Jan 28, 2008 at 4:03:43 PM | HELP! Callout modifications
Katwoman
My boss wants the drawings to read without competing with the callouts...although we all know this has been an industry standard for sometime he wants me to find a way to make the callout read as text rather than the dashed rectangle with the callout. (Refer to sheet x/xxx for enlarged plan) I've tried modifying the family parameter to make an "on/off" label, but the labels have defaulted parameters I can't modify.
1. Is there a way to modify the parameters that are pre-set?
2. How can I turn on the rectangle callout box while editing the callout tag? I see the bubble but not the dashed box when I open the annotation family.
3. Is this impossible in this version?
My boss is very reasonable, I just need to have accurate information before I tell him, "it's not possible". "Workarounds" are not acceptable solutions here as we'd be using Autcad if we did not want to utilize Revit for all it's value of cross referencing etc! Thanks!!!!
Tue, Jan 29, 2008 at 10:56:12 AM | HELP! Callout modifications
NKramer
4 Stars: 9 Votes
Is this what you want? In order to use this you have to Settings: View Tags: Duplicate one of the exsisting tags, and change the callout head. After this is done then you need to select the callout head that you want to change (i.e. detail, plan, etc) select element properties, edit/ new, duplicate the type, and then change the callout tag to the one you created above. Kind of a round about odd way but thats the way Revit works and this way you can use the same CalloutHeads for multiple callout types.
Just an FYI instance parameters do not work in annotation families. You have to use type parameters and set up multiple types.
HTH
Nick
EDIT: BTW this only appears to work in regular views. I tried useing this family to modify my callouts within details (we typically place detail cross references within text) but it keeps switching back to the default circle, dont know why. You can change the detail callouts individually in plan, but the enlarged plan callout is global. Just some quirks that I have come accross. Wish you could actually use the items that Revit lets you modify, but sometimes they just get lost in limbo....
Edited on: Tue, Jan 29, 2008 at 11:11:01 AM
Fri, Feb 1, 2008 at 9:32:34 AM | HELP! Callout modifications
Katwoman
Thanks, but it's much more complicated than this. What I want is the ability to turn off the callout boundary so that only text is left in lieu of a callout bubble...right now I'm creating a callout bubble for floor plan. 2. Create new callout and reference the same view. 3. Turn off the original, I understand Revit needs the callout to bound the view...4. I then shrink the referenced callout so that you only see text RE: 1/A201 FOR ENLARGED PLANS.
I'm not the boss...this is riddled with problems, but this is the way he wants it...this is my temporary workaround for now.
Fri, Feb 1, 2008 at 2:41:13 PM | HELP! Callout modifications
NKramer
4 Stars: 9 Votes
What you are asking for is not really possible to do within the family. You could look into visability/ graphics overrides but I dont think that that is available either. You could also look into changing the callout linetype to a really skinny white. It would leave a thin "blank" line in the middle of the walls that it cuts but would still be parameteric...
I have never seen a set of plans that does not denote the area of the callout, but I guess It could have it's uses.
Nick
Fri, Feb 1, 2008 at 5:15:40 PM | HELP! Callout modifications
Katwoman
Honestly I think it's terrible to not have a callout...this is an industry standard that has been around for sometime! Hmmm can you tell I'm frustrated? It would however be useful if Revit programmers will listen to the pleas for a polygon option!
 I had tried the white line option before, but it unfortunately changes ALL callouts and we do want some detail callouts with bubbles, just the enlarged floor plans without...it's not looking promising.
Mon, Nov 24, 2008 at 12:42:46 PM | HELP! Callout modifications
RobSawall
Maybe this will help, maybe it wont.  Right click on the callout instance and select Override Graphics in View > By Element.  Change the Line Weight to 1 and Color to White.  Your text will print out but no boundary.
Mon, Nov 24, 2008 at 2:54:32 PM | HELP! Callout modifications
Katwoman
That works perfectly, thanks!
Mon, Oct 1, 2012 at 8:48:18 AM | HELP! Callout modifications
rahulk1984
rahulk1984 Avatar
Go to Object Style and the line type what ever you want.
Edited on: Mon, Oct 1, 2012 at 8:49:23 AM
Mon, Oct 1, 2012 at 10:44:05 AM | HELP! Callout modifications
4 Stars: 205 Votes
This thread it's from 4 years ago....
Tue, Nov 26, 2013 at 12:56:26 PM | HELP! Callout modifications
RICKY2020
I ran into this problem when i first started, all you need to do it to go to manage/additional settings/call out tag/ and from type properities set the call out head to none. Then you can draw a line attached to it and type whatever. if you want to make the actual callout then you will need to go to new/family/annotation/callout tag and then lable whatever you need
Fri, May 16, 2014 at 2:51:30 AM | HELP! Callout modifications
#11
KAM1
Cheers Ricky, big help there, struggling with tags for a while now, cad/revit crossover happening and it ain't pretty
Detail Callout Issue
Tue, Jan 25, 2011 at 12:57:36 PM
Callout tags
Thu, May 1, 2008 at 11:39:20 PM
12
callout only head
Tue, Mar 26, 2013 at 7:09:20 AM
CALLOUT ISSUES
Thu, Oct 9, 2008 at 3:34:15 PM
Rotate Callout Head?
Thu, Aug 1, 2019 at 10:08:02 AM
Page generation time: 1.0809
