Forums >> Revit Systems >> Technical Support >> How to add Curtainwall Doors to a Door Legend
Fri, Jan 25, 2008 at 9:52:35 PM | How to add Curtainwall Doors to a Door Legend
iremulla
I have a door legend started, but I can't seem to add any curtainwall doors to my legend.  Any advice?
Sat, Jan 26, 2008 at 4:39:33 PM | How to add Curtainwall Doors to a Door Legend
NKramer
4 Stars: 9 Votes
The problem is that curatin wall doors arent quite doors. Try grabing it from the family list. You should be able to find it there under curtain panels.
HTH
Nick
Sat, Jan 26, 2008 at 7:39:18 PM | How to add Curtainwall Doors to a Door Legend
iremulla
thanks for trying to help.  i realize that the curtain wall doors are actually panels, but I still can't grab them from the family list and drop them into my legend.  any suggestions?
Sun, Jan 27, 2008 at 6:16:10 PM | How to add Curtainwall Doors to a Door Legend
NKramer
4 Stars: 9 Votes
Sorry I had not actually tried that, but your right it doesnt work. I guess you just have to create a fake one (similar to elevation callouts in legends) either as a family or just using detail lines. The only other option would be to use an actual elevation of the door and overlay that with your legend.
I actually use elevations for window schedles in order to get all of the labeling functionality.
Workaround....
Nick
Curtainwall Legend
Mon, Aug 6, 2007 at 10:33:19 AM
about door legend
Wed, Oct 26, 2016 at 10:48:38 AM
Curtainwall door mullion/jamb issue - door is wider than inside mullion spacing
Mon, Jan 19, 2015 at 7:41:36 AM
Trick for placing doors in Curtainwall.
Wed, Feb 27, 2008 at 5:59:49 PM
window and door legend
Thu, May 10, 2007 at 9:16:26 AM
Page generation time: 1.9497
