Forums >> Revit Building >> Technical Support >> Sloping Wall Sweeps (Revit 2008)
Fri, Jan 25, 2008 at 7:51:23 PM | Sloping Wall Sweeps (Revit 2008)
Robles
Anyone know how to make sloping wall sweeps?  E.g. a sloping cornice along the RAKE side of a gable roof.  Having no problems adding cornice wall sweeps to eave side b/c there is a button to change them from horizontal to vertical, but apparently nothing for angles (to match slope of the roof).  Any insight is appreciated.  Thanks!
Fri, Jan 25, 2008 at 11:12:24 PM | Sloping Wall Sweeps (Revit 2008)
TRUEVISIONS
Robles,
    This is just one way to do it... Creat a facia profile that matches that of the cornice that you wish to use. Then all you need to do is select the lower side of the sloping roof and set an negative ofset horiz. inorder to place it alone side the house. You can also adjust it vertically +-.....Hope this does what you want..Good luck and If I can help any more let me know.
TRUEVISIONS
JED
Sat, Jan 26, 2008 at 9:13:08 PM | Sloping Wall Sweeps (Revit 2008)
Robles
i'LL TRY IT OUT...thanks TRUEVISIONS!
Help... Applying Rendering Texture to Sloping Wall
Mon, Dec 8, 2008 at 5:47:54 AM
Precast on curved sloping wall
Sat, Nov 22, 2008 at 1:35:25 PM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Wall sweeps / mitering
Sat, Jan 31, 2009 at 4:26:09 PM
Sloping wall
Mon, Sep 24, 2007 at 9:10:38 AM
Page generation time: 7.1255
