Forums >> Revit Building >> Technical Support >> equipment screen
Fri, Jan 25, 2008 at 4:13:23 PM | equipment screen
mteag
using Revit 2008
Trying to create a family for an equipment screen. C/S Vert-a-cade 301 has louvers every 6" horiz. mounted on 2.5x2.5 vertical angles. I've not had any trouble modeling the pieces of the screen, but I'm not sure whether to model them as a curtain wall panel, use the generic template, etc.
I'm uploading a file of the screen modeled as a curtainwall panel. I loaded it into my project and set up a curtainwall type to use this as the panel. However, I can't adjust the length of the panel. Even though the curtainwall is cleaning up at the corners the 20' panels are extending into space instead of mitering or butting into a corner mullion.
I don't know if I should keep the 2.5" angles in the same family as the louvers or define them as mullions. I wanted a good family where the height and length are adjustable, and the angles automatically space themselves max 6 ft apart. I don't like the way this is turning out as a curtainwall.
Help please
equipment screen?
Fri, Jan 25, 2008 at 3:37:27 PM
Equipment Schedules
Tue, Jun 17, 2008 at 11:39:12 AM
Mechanical Equipment pipe connectors...
Tue, Nov 18, 2008 at 11:21:28 AM
Medical Equipment
Mon, Apr 30, 2007 at 10:12:25 AM
All my mechanical equipment is showing up on all the levels
Mon, Jun 11, 2018 at 2:55:08 PM
Page generation time: 0.1307
