Forums >> Revit Building >> Technical Support >> equipment screen?
Fri, Jan 25, 2008 at 3:37:27 PM | equipment screen?
mteag
I've been attempting to create a family for an equipment screen. I've tried it using the imperial generic template, a curtain wall, curtain wall panel.
I haven't had any trouble modeling the actual pieces of the equipment screen, but I must not have the family set up correctly. Please advise on the best way to go about this.
The screen has louvers spaced 6" apart, mounted horizontally to 2.5"x2.5" angles. I thought about leaving out the vertical supports altogether and just drafting them in details for simplicity in the 3D model.
I think I figured out how to get the # of louvers in the array to be Length / 6".
This family isn't coming into my project in a way that I can use it (adjust length, trim corners, etc.) I've attached a file that when I load into project is a curtainwall panel. So I draw a curtain wall and set this as the panel. It doesn't clean up at corners. I'm thinking of taking the angles out of the family and making those mullions. Don't know if this is the right way to go about it at all.
Help please!
equipment screen
Fri, Jan 25, 2008 at 4:13:23 PM
Equipment Schedules
Tue, Jun 17, 2008 at 11:39:12 AM
Mechanical Equipment pipe connectors...
Tue, Nov 18, 2008 at 11:21:28 AM
Medical Equipment
Mon, Apr 30, 2007 at 10:12:25 AM
All my mechanical equipment is showing up on all the levels
Mon, Jun 11, 2018 at 2:55:08 PM
Page generation time: 2.0853
