22 Users Online (20 Members):
Forums >> Revit Systems >> Technical Support >> robobat robot files
4 Posts No Rating |
hi can anybody tell me how from revit structure 2008, i can import and export files from the analysis package Robot. regards les
Hey dabbler45, This process has really been simplified in 2008. The easy way, go to: www.extensions4revit.com (currently under construction) and download their extensions. You will need their engine and what not. After you install them you have a new tool bar and menu inside RST that will have import/export options on it. The really nice thing is you will be able to export to the native Robobat file. I would also look at downloading the other extensions as thay can be really helpful. HTH Brett
4 Posts No Rating |
Thanks Brett. I will try that when the site is up and running. Cheers
4 Posts No Rating |
Hi Brett I have downloaded extensions. Stlli cannot open Robot file with Revit. I am working over a network, so the Robot and Revit programmes are on different machines. I believe I need to have at least an unlicensed version of Robot on same machine as Revit is on. Is this true ? Regards Les
Hey, Yes, you will want to have at least one version of Robot on your computer. If you go to robobat's website, they do offer a freeware download that might be able to help you out. Brett
Error message when importing Robot Millennium buildingmodel |
Mon, Mar 5, 2007 at 5:13:15 AM
revit structure to robot millennium |
Fri, Dec 26, 2008 at 4:08:18 AM
Unknown Run-Time Error (Revit to Robot) |
Mon, Dec 27, 2021 at 2:24:48 PM
Unable to start robot analysis structure (HELP NEEDED) |
Tue, Apr 29, 2014 at 10:11:09 AM
robot into revit |
Wed, Apr 2, 2014 at 9:27:48 AM
