Forums >> Revit Building >> Technical Support >> How to get Volume for Family object
Thu, Jan 24, 2008 at 6:21:01 PM | How to get Volume for Family object
andy1289
If anybody knows how to get Volume for Family object?
May be I can use Autocad to get it?
Thu, Apr 14, 2011 at 1:26:19 PM | How to get Volume for Family object
lynner
I have this question too - I'd like to find a way to schedule volume of an object within a family (as a reporting parameter).  I'm trying to make a family to represent tanks in an aquarium.. Not all the tanks will be rectangular so I am hoping to not use a formula.
Thu, Apr 14, 2011 at 2:59:18 PM | How to get Volume for Family object
pchan
pchan Avatar
5 Stars: 5 Votes
I think you will have to use share parameters and set up a formula inside the family in order to get the "volume" (which should be a parameter) to show up in a schedule. A simple formula (like Length x Width x Height for rectangle shape should do it)
Thu, Apr 14, 2011 at 3:19:30 PM | How to get Volume for Family object
TKennedy
4 Stars: 8 Votes
Something else you could do is to create a material takeoff schedule. It wouldn't be a parameter inside your family, but it should work for any shape or size of family.
Thu, Apr 14, 2011 at 3:23:25 PM | How to get Volume for Family object
lynner
If I only had rectangular elements that would be fine, but i will also need to be scheduling volumes for elements that are cylindrical, trapezoidal, etc.. not all symmetrical and some made as in place families.   It seems like I can do it with a mass family, but that of course creates funky issues with visibility.
Thu, Apr 14, 2011 at 3:28:47 PM | How to get Volume for Family object
lynner
thanks TKennedy - that's a perfect solution!
Thu, Apr 14, 2011 at 3:35:23 PM | How to get Volume for Family object
pchan
pchan Avatar
5 Stars: 5 Votes
I am not sure if using mass family is a good idea though since they can't be scheduled in material takeoff
Thu, Apr 14, 2011 at 3:45:32 PM | How to get Volume for Family object
lynner
Calculating Volume
Tue, Sep 4, 2007 at 2:35:09 AM
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Pulling System Parameter From Nested Family
Wed, Jan 9, 2019 at 8:58:25 AM
Adding Volume Parameter into a family
Fri, Aug 30, 2013 at 11:37:25 AM
Generating Volume from In-Place Families
Thu, Jul 2, 2009 at 11:33:38 PM
Page generation time: 1.5040
