Forums >> Community >> Newbies >> Newbie. Need help with some things
Thu, Jan 24, 2008 at 1:07:50 PM | Newbie. Need help with some things
arch2student
Like:
How do you change the walls to the bricks designs. the gray is boring.
I have Revit arch 2008
Thu, Jan 24, 2008 at 1:33:50 PM | Newbie. Need help with some things
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Right click on a wall and go to Properties. Click the Edit/New button and click the structure button. You can then set up the compound wall and attach the materials. You may need to set up the desired material first though. To do this go to Settings-->Materials and you can create all sorts of materials here. Let us know how your progress goes.
Thu, Jan 24, 2008 at 5:08:50 PM | Newbie. Need help with some things
TRUEVISIONS
If you have already created all your walls and you want a quick fix. You can use the paint bucket and select the material you want the wall to be. This keeps what ever wall structure that you had orriginally but just changes the outside face. This way you can make it what ever you want...temp...or perminent.....   Brick,glass,horiz.,or vertical...
Good luck..and enjoy REVIT
TRUEVISIONDESIGNS
JED
Thu, Jan 24, 2008 at 5:42:09 PM | Newbie. Need help with some things
arch2student
Soory to bother you again. I tried both ways. For the 1st suggestion, I tried, but got lost while trying to set the compund wall. I actually had success with the second one. But I don't have many options. How do you add more 'paint schemes' if that is what you call them. thanks for the Help. This is my first week with Revit. I always used AutoCad.
Thu, Jan 24, 2008 at 5:45:07 PM | Newbie. Need help with some things
arch2student
I also found the material library. How do I make it show up on my walls.
Thu, Jan 24, 2008 at 6:10:07 PM | Newbie. Need help with some things
arch2student
TRUEVISIONS- My goal is to make the walls like the brick on the entrance of your entry perspective drawings, in the gallery. Nice work on all of those, by the way.
Thu, Jan 24, 2008 at 6:14:13 PM | Newbie. Need help with some things
TRUEVISIONS
contact me via chat and I will give you a walk through
Thu, Jan 24, 2008 at 7:27:14 PM | Newbie. Need help with some things
arch2student
Thanks for all your Help TRUEVISIONS
Wed, Jan 30, 2008 at 1:13:54 PM | Newbie. Need help with some things
arch2student
I have to create a walk-out basement house. How do you create a rendering with a ground plane that can act as real ground, and use slopes from the lot
Wed, Jan 30, 2008 at 1:29:29 PM | Newbie. Need help with some things
TRUEVISIONS
arch2student,
     What you do to create a "walk-out" basment is this. Create the house. Create a topo that slopes to the house as desired. Set the topo to the desired material/materials.. (grass, concrete, earth..) Go to SETTINGS, sellect SUN AND SHADOW SETTINGS, de-select the Ground Plan option. This will then render the sloping topo and all the floor plan levels. Be sure to make the topo extend past the desired image crop. Hope this helps..Let me know if you have further problems.
TRUEVISIONS
JED
Tue, Feb 5, 2008 at 1:06:47 PM | Newbie. Need help with some things
#11
arch2student
Thanks for all your help. I just got back in town, and finished my topo quickly. Now, I am interested in finding out how to do night renderings.
Beams & Things
Tue, Aug 9, 2005 at 12:44:44 AM
Newbie
Thu, Apr 27, 2017 at 9:35:53 AM
Newbie
Tue, May 15, 2012 at 8:01:26 AM
Not so Newbie
Fri, Aug 14, 2009 at 12:39:04 PM
Revit MEP 2008 Newbie!
Mon, Oct 1, 2007 at 10:00:09 AM
Page generation time: 0.3094
