Forums >> Revit Structure >> Technical Support >> View Title Line Thickness
Thu, Jan 24, 2008 at 12:20:04 PM | View Title Line Thickness
Chazbo
In the Revit Building >> Technical Support forum, Lizard 2806 offers the following to modify the view title line thickness...
...select the viewport title, then go into preferences, then click Edit/New.  There you have the option of changing the line weight and line pattern...
But I am unable to follow this since there are no preferences.  In Revit Structure 2008, how does one control the title line thickness?  Thanks.
Thu, Jan 24, 2008 at 1:42:39 PM | View Title Line Thickness
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Right click a view on a sheet and go to Properties. Then click Edit/New and you will see a parameter call Lineweight. Change it there. I believe Lizard2806 meant "Properties" instead of "Preferences"
Changing Line Thickness within a View Title Family...
Fri, Jun 15, 2012 at 12:05:37 PM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
View Title Extension line
Mon, Apr 23, 2007 at 6:38:22 PM
Imported AutoCAD 2006 title block line thickness
Thu, Sep 7, 2006 at 3:27:44 PM
Automatic View Title Extension Length
Sun, Dec 18, 2016 at 5:45:56 PM
Page generation time: 0.7579
