Forums >> Community >> Newbies >> Problem with my column
Thu, Jan 24, 2008 at 10:56:32 AM | Problem with my column
MARS1276
1 Stars: 1 Votes
I created a structural C-channel column and managed to give it an assigned height.  But when I assign the levels that it is suppose to extend to it doesn't change height to meet that level/height.  Also, when I attach it to my roof it doesn't extend to meet the roof.  What do I need to do?
Tue, May 6, 2008 at 5:35:47 PM | Problem with my column
AbelGoddard
AbelGoddard Avatar
Sounds like you need a parameter that allows adjustment. In an elevation view of the family, draw a dimension from top to bottom. Assign a 'height' parameter, so that it can be adjusted as necessary. You can make it adjustable per type or per instance. I think you want per instance in this case.
Helping you Be Able to be the person you want to be!
Sign up for my free newsletter, Being Able, at http://www.AbelGoddard.com
Graphical Column Schedules problem....
Wed, Sep 9, 2015 at 12:41:56 PM
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:07 PM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Tagging Graphical Column Schedule
Wed, Nov 24, 2010 at 8:41:14 PM
column visibility issues
Tue, Mar 11, 2008 at 12:08:15 PM
Page generation time: 1.0657
