Forums >> Revit Structure >> Technical Support >> Graphics overrides.
Wed, Jan 23, 2008 at 3:04:45 PM | Graphics overrides.
TJKENNEDY
3 Stars: 2 Votes
Our current office standard for showing wood bearing walls is to use a slightly heavier lineweight for dashed walls below. This makes it easier to see the walls stacked on top of each other. We only do this for wood, not concrete, cmu, etc.. Is there any way to do this in Revit?
Wed, Jan 23, 2008 at 4:44:23 PM | Graphics overrides.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
If you are using RA2008 you can select the items you want to modify and right click and select Overide Graphics in View-->By Element. You can then select the cut line pattern and thickness you desire.
Wed, Jan 23, 2008 at 4:58:37 PM | Graphics overrides.
TJKENNEDY
3 Stars: 2 Votes
That works for a few elements but I want to automatically do it for every wood bearing wall.
Thu, Jan 24, 2008 at 9:18:27 AM | Graphics overrides.
CADorangutan
Read up on View Templates.  These are critical for outputing model information specific to view type and minimize.  EX:  We have a standard view template created for 1/8" = 1'-0" plan views.  This can be set in one view based on your scale and view type criteria and applied to all other views of the similar type.  This will dramatically minimize overriding elements one by one while ensuring standards are maintained.  Additionally, this also reduces items such as how many line types you need in a file.  This should help your Carpal Tunnel Syndrome  Smile
Ee
Visibility Graphics/Overrides COMPLETELY grayed out. Revit Structure 2013.
Tue, Mar 27, 2018 at 3:22:42 PM
Model elements not displaying correctly
Thu, Oct 27, 2016 at 10:41:34 AM
Filters in visibility graphics
Wed, Feb 4, 2015 at 7:43:00 AM
''Visibility grafics'' and ''create parts'' problem when mak
Thu, Mar 18, 2021 at 2:12:06 AM
Removing categories from Graphic Overrides
Mon, Jul 14, 2008 at 6:58:05 PM
Page generation time: 0.3529
