19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Foundation Walls not mitering?
Why don't my foundation walls miter when I miter the walls they are supporting? The foundation walls just cut the corner out? Anybody know the answer or solution to this? Thanks, Lorne
Denver, CO
Revit Architecture |
Unless the foundation walls are part of a stacked wall, you will have to set the mitre condition seperalely from the walls. I did a test on the default foundation wall and I was able to mitre it.
How do I set the mitre condition separately? I don't want to make them stacked walls...cuz then the base of my wall is not at the correct plan, i.e. floor level.
Denver, CO
Isolate the foundation walls, (this is to make sure you are selecting them) click on the "Edit Wall Joins" button and select one of the corners. Click "Miter" button. Repeat for all corners.
Oh I wasn't aware that was what you were refering too. Thanks
Denver, CO
Foundation walls in elevation |
Sun, May 22, 2005 at 8:46:49 PM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Foundation Wall Issue |
Tue, Mar 23, 2010 at 4:59:46 PM
Foundation plan/level view (R2013) |
Wed, Nov 14, 2012 at 12:19:31 PM
Foundation Thickening |
Thu, Jul 3, 2008 at 9:39:52 AM
