Forums >> Revit Building >> Technical Support >> 3D in place sweep problem, changes angle
Tue, Jan 22, 2008 at 5:59:38 PM | 3D in place sweep problem, changes angle
matlock
matlock Avatar
4 Stars: 6 Votes
Im trying to put this sweep trim on the wall as shown. the profile changes angle as it turns the corner and goes down. this is undesirable.....how can i keep it flat to the wall?
Tue, Jan 22, 2008 at 6:53:14 PM | 3D in place sweep problem, changes angle
eldados
eldados Avatar
4.5 Stars: 8 Votes
are you sure you are picking the wall? it looks like you are picking something else, try to isolate the wall just to make sure...
Integrator
KarelCAD
Wed, Jan 23, 2008 at 10:24:46 AM | 3D in place sweep problem, changes angle
matlock
matlock Avatar
4 Stars: 6 Votes
this is positively connected to the wall as shown at the bottom of the picture attached. section B. I wonder why its doing this and how a can make it work. my goal is to have that trim go all the way around the top of the building in the picture...
Mon, Jan 28, 2008 at 12:56:37 PM | 3D in place sweep problem, changes angle
matlock
matlock Avatar
4 Stars: 6 Votes
I fugured it out.....
FYI.....
I had to jog the sloped wall over alittle to allow for the thick sweep profile to fit and turn down.... see the pic...
Generic line based sweep
Mon, Jan 28, 2013 at 5:06:38 AM
rotate sweep
Thu, Jul 26, 2007 at 11:05:56 AM
Sweep problem
Wed, May 21, 2014 at 9:21:16 AM
Cut wall sweep in line with top of angled wall?
Sat, Oct 15, 2016 at 11:38:08 AM
CREATE IN PLACE SWEEP GONE WRONG
Mon, Jan 28, 2008 at 1:11:48 PM
Page generation time: 0.7550
