Forums >> Revit Building >> Technical Support >> Upgrade file from 5.1 to Revit Archiecture 8
Tue, Jan 22, 2008 at 5:28:16 PM | Upgrade file from 5.1 to Revit Archiecture 8
johnalgeo
I guess I have been using Revit for a long time.
I have a 5.1 file that will not load into Revit Building 8 or 9.1.  Any suggestions?
 Thank you for your help.
JSA
john a
Tue, Jan 22, 2008 at 7:02:56 PM | Upgrade file from 5.1 to Revit Archiecture 8
eldados
eldados Avatar
4.5 Stars: 8 Votes
I think you will have a problem upgrading the 5.1 (anything before 6)
there is a new 2008 build available that fix this problem, try that.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=9262001
Integrator
KarelCAD
Tue, Jan 22, 2008 at 7:19:00 PM | Upgrade file from 5.1 to Revit Archiecture 8
johnalgeo
Thank, I'll donwload it tonight'
 JSA
john a
UPGRADE QUESTION
Mon, Jun 12, 2006 at 9:03:39 AM
UPGRADE problem!!!
Wed, Jun 28, 2006 at 6:35:24 AM
Revit upgrade files to 2011
Wed, Jul 28, 2010 at 12:23:51 PM
batch upgrade crashes on start
Thu, Sep 18, 2008 at 1:38:44 AM
Revit 2011 upgrade
Fri, Jul 2, 2010 at 7:15:32 AM
Page generation time: 2.5139
