Forums >> Workflow & Implementation >> API & Third Party Apps >> Render list of views
Search this ThreadSearch this Thread | Page 3 of 7 | << Previous 1 | 2 | 3 | 4 | 5 Next >>
Mon, Oct 15, 2012 at 8:24:41 AM | Render list of views
#31
frifer
5 Stars: 4 Votes
its always posted in the first post at the bottom.. Smile
2 big bugs that caused crashes, you should update.. Smile
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Mon, Oct 15, 2012 at 10:16:04 AM | Render list of views
#32
4 Stars: 205 Votes
I will, thanks Frifer...
Tue, Oct 16, 2012 at 12:59:24 AM | Render list of views
#33
frifer
5 Stars: 4 Votes
you're welcome! Smile
Sun, Nov 11, 2012 at 12:47:43 PM | Render list of views
#34
riarchitect2012
riarchitect2012 Avatar
4.5 Stars: 25 Votes
Hello again,
I know it has been a while,I just want to thank Frifer for his efforts, the plugin didn't work in my PC for a long time, but thanks to the perseverance of Frifer it worked at last...now I  can have a good night sleep while revit do all the renderings... so thanks again.
Mon, Nov 12, 2012 at 1:05:16 AM | Render list of views
#35
frifer
5 Stars: 4 Votes
Smile youre welcome! nic eto hea that you enjoy it! Smile
Fri, Nov 16, 2012 at 10:32:40 AM | Render list of views
#36
Mboyer
So I've downoaded the files and followed the instructions.  The add-in does show up in Revit, however when I click on it, nothing happens.  I'm using Revit 2013 from the Building Design Suite.  Am I doing something wrong?
Regards,
Marc Boyer
Mon, Nov 19, 2012 at 12:50:13 AM | Render list of views
#37
frifer
5 Stars: 4 Votes
Hello!
well if you installed it and it shows up i think there is nothing you can have done wrong.. (i think at least..)
you could verify these things:
1) everything is on c: drive (revit and the add in)
2) reinstall .net framework 3.5 and 4
please try these two things and let me know.
also please let me know the language of your OS and your Revit version.
Thanks
Igor
Mon, Nov 26, 2012 at 2:10:53 AM | Render list of views
#38
frifer
5 Stars: 4 Votes
Hello Marc!
any news on your end? did you solve the problems?
bestregards
igor
Sat, Dec 28, 2013 at 7:28:49 PM | Render list of views
#39
orv
4.5 Stars: 7 Votes
hello , its this working with revit 2013? and Revit 2014?
Because a tried ont both and non works!!
 Thankz
Edited on: Sat, Dec 28, 2013 at 7:29:27 PM
Mon, Jan 6, 2014 at 11:45:26 AM | Render list of views
#40
rinlok
Hi! Thanks for the creating the add-in and offering it to us! Any updates coming our way for 2014?
Edited on: Mon, Jan 6, 2014 at 11:49:16 AM
Tue, Jan 7, 2014 at 3:29:32 AM | Render list of views
#41
frifer
5 Stars: 4 Votes
Hi guys!
2013 should be working fine with the plugin..
i will try to release a 2014 version anytime soon.. but first i have to update to revit 2014 myself. will keep you posted.
Tue, May 6, 2014 at 1:27:54 AM | Render list of views
#42
frifer
5 Stars: 4 Votes
Guys sorry for the late update! updated it to 3.1 that should be compatible with revit 2014!
The release for 2015 will be faster! Smile
Mon, May 12, 2014 at 6:58:39 AM | Render list of views
#43
frifer
5 Stars: 4 Votes
As promised i released the version for 2015!
Attention! 2015 requires .net framework 4.5.1
Please report any problems!
Tue, May 13, 2014 at 8:44:09 AM | Render list of views
#44
RVANL
I can't get your plugin to work. I followed the installation instructions. The external tools icon is present in the add-in ribbon but nothing happens when I click 'Render Views'
I'm using revit 2014 on windows 7.
Any idea?
Tue, May 13, 2014 at 9:51:52 AM | Render list of views
#45
frifer
5 Stars: 4 Votes
Hello!
did you get a chance to select the views to render?
do you have some 3D views ready?
did you install .net framework 4.5?
whats the language of your revit?
is the text "render views" grayed out?
also keep an eye on the BLUE text as it tells you what you have to do.
regards
Igor
Edited on: Tue, May 13, 2014 at 9:54:50 AM
Render List of Views 2017
Wed, Apr 5, 2017 at 10:17:53 AM
Elements Missing in Render Image
Mon, Sep 27, 2010 at 7:21:17 AM
Drawing list gone
Thu, Nov 1, 2012 at 1:57:58 PM
can't find the render button
Mon, Nov 15, 2010 at 12:15:12 PM
2013 Graphics card driver list
Tue, May 8, 2012 at 9:29:58 AM
Page generation time: 0.7357
