Forums >> Community >> Newbies >> Rendereing
Search this ThreadSearch this Thread | Page 3 of 3 | << Previous 1 | 2 | 3
Tue, May 22, 2012 at 11:27:54 AM | Rendereing
#31
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
easiest way to drop the topography down is to go to an elevation, select it, and just use the move tool to move it down a few inches.  The other way to edit topo is to select it, hit "Edit Surface" (a button that'll appear in the upper right) and then select each topo point and change it's value (likely the default 0' 0") to something negative, like -0' 2".
But I'd just move it down for now.
Tue, May 22, 2012 at 12:49:13 PM | Rendereing
#32
Paulinak73
DONE!!! You were absolutely right, thank you so much for your time !!! I truly appreciate it Smile)))
Tue, May 22, 2012 at 12:53:33 PM | Rendereing
#33
4 Stars: 205 Votes
Just a question: inside your building didn't you create a PAD ?
Tue, May 22, 2012 at 1:03:22 PM | Rendereing
#34
Paulinak73
Yes, pad is there Smile
Tue, May 22, 2012 at 1:09:05 PM | Rendereing
#35
4 Stars: 205 Votes
So.. if you have a PAD why your topo is showing in that view? also, just change the "Height offset from level" of that pad...
Tue, May 22, 2012 at 2:21:29 PM | Rendereing
#36
itsmyalterego
4 Stars: 16 Votes
It was just a floor -- Paulina -- pads are technically a different tool than a floor--under the massing and topography tab--which either pulls up topography to the bottom of it, or depresses topography.
They're handy in some cases.
Tue, May 22, 2012 at 2:29:34 PM | Rendereing
#37
Paulinak73
Aaa! Thank you again. Learning a lot from this discussion!
rendering light source
Mon, Dec 19, 2011 at 3:21:42 PM
Renderer Plugin for low end school laptop
Tue, May 13, 2014 at 6:06:26 AM
"Render" button greyed out
Mon, Feb 15, 2010 at 1:57:13 PM
Revit VS. ADT2005
Mon, Apr 4, 2005 at 9:23:20 PM
Page generation time: 0.0332
