Forums >> Revit Building >> Technical Support >> CAD files importing with huge blank space
Wed, Sep 1, 2010 at 4:25:15 PM | CAD files importing with huge blank space
#16
spohler
I had the same problem. I had made sure there was nothing out there in space, it was flat, etc. But it seems my problem was within the blocks. Once I exploded, purged and imported, everything came out fine.
And thanks for teaching me the Positioning: Manual, I have been struggling with placement of my CAD imports!
Fri, Sep 3, 2010 at 11:43:39 PM | CAD files importing with huge blank space
#17
BCMArch
BCMArch Avatar
Unbelievable-
Almost three years and 680 views and 15 attempts to answer
this simple question.. THAT is amazing..
When you import a DWG into a revit project you are doing
something that should not be done in the first place- BUT
if you insist- then all you need to do to get it to the scale
you want is set the import scale. yup- it's that's simple..
You have to set the scale MANUALLY almost everytime
you import a DWG. That means "custom" scale. You
don't know exactly what that scale should be-  so you
"test" it by setting the custom scale to maybe .04.  And
then re-import it with a different setting if you don't
like the size- until you get it close to the size you want.
Or you could even get it to the exact scale that way.
Gee where have all the revit gurus been hiding?
Importing Paper Space/Model Space from CAD File
Mon, Nov 17, 2014 at 9:46:02 AM
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:43 PM
Importing CAD 3D
Sat, Mar 7, 2009 at 7:26:45 AM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
Page generation time: 1.0162
