Forums >> Revit Building >> Technical Support >> Please state Revit version being used in your questions
Wed, Nov 5, 2014 at 10:31:09 PM | Please state Revit version being used in your questions
#16
RevitCityMC
Hi there can someone please help me! I just downloaded Revit 2013 and now when i go to use it all of the tools are shaded and i cant click on them (all except a couple like components). How do i fix this? I thought maybe it had something to do with my lisence? Any help would be greatly appreciated!! (Im new to reivt!)
Thu, Nov 6, 2014 at 7:27:53 AM | Please state Revit version being used in your questions
#17
2013 had several updates.   Install all of them.
Why are you using 2013?   2014 is so much better and the current release is 2015.   I would move on if you can.
Fri, Apr 22, 2016 at 5:27:55 PM | Please state Revit version being used in your questions
#18
Ipauline
Hello, I'm currently using Revit 2014. I have made several attempts to create sheet sets by by loading from the title Block Family, no issues there. However when dragging my views into a sheet Revit closes and doesnt save my latest changes. I did notice that my view seemed to go into the SUPERSTRUCTURE page, pretty weird. Is there something I need to set up in order to get my views to populate title blocks?
Thanks,
Ivan
Sun, Apr 24, 2016 at 6:18:42 PM | Please state Revit version being used in your questions
#19
Same answer as before.  Have you got all updates installed?
We used 2014 for a long time without any issues and there is nothing special about placing views on sheets.
Sun, Apr 24, 2016 at 7:56:29 PM | Please state Revit version being used in your questions
#20
Ipauline
The sheet set function doesnt usually require and update, this is a default loaded function. Further Revit has not required an update by way of a system generated notification. There has to be another way to get this information. I will just seek an answer from Autodesk.
Thanks
Sun, Apr 24, 2016 at 8:11:22 PM | Please state Revit version being used in your questions
#21
Ipauline
Ok so I'm making sure by downloading Revit 2014 UR3 and see if that fixes the issue with sheet set and view drag. Thanks for the info!
Wed, Dec 14, 2016 at 7:37:35 PM | Please state Revit version being used in your questions
#22
diamondbrian
I am using Revit 2015.
Has anybody ever had an issue that when flipping work sets for random geometry the geometry physically moves location?
If yes how do you resolve?
Thu, Dec 15, 2016 at 6:32:17 AM | Please state Revit version being used in your questions
#23
How do you flip a workset?  NOT POSSIBLE!  Please explain what you are trying to do.
Revit and solid state hard drives
Mon, Feb 2, 2009 at 9:31:28 AM
Convert to State Plane Coordinates in Revit 2012
Wed, Nov 16, 2011 at 8:01:56 AM
revit latest version cannot be save to a lower version
Wed, Apr 27, 2011 at 10:00:25 AM
Hello from the 49th State!
Sun, Aug 15, 2010 at 12:44:23 PM
Are solid State drives ok for Revit Architecture?
Wed, Nov 9, 2011 at 11:08:24 AM
Page generation time: 1.6773
