Forums >> Revit Building >> Technical Support >> When you can't make all walls join correct, what you do?
Wed, Oct 7, 2015 at 2:15:30 PM | When you can't make all walls join correct, what you do?
#16
rabbitcookies
Actually, it helps! I removed some room seperation lines overlapping with exterior walls, and the problematic corners fixed surprisly... Not sure why, though.
walls won't join
Fri, Oct 31, 2008 at 2:31:33 PM
Revit Can't cleanup walls with Modified vertical structure
Fri, Mar 7, 2014 at 11:34:30 AM
walls overlap but dont join.
Sat, Jul 30, 2016 at 5:13:58 PM
90degree wall join
Sun, Aug 20, 2006 at 9:08:54 PM
un-join walls
Wed, Mar 15, 2006 at 6:29:53 PM
Page generation time: 1.0936
