Forums >> Revit Systems >> Technical Support >> Render Problems
Mon, Jan 13, 2014 at 12:26:39 PM | Render Problems
#16
You really don't have to.  When I find this problem, I remove the family then I rename the material that still exists in the project.  Now I can load the family with the correct material.
If you really want to find out where it is, you can use a material takeoff and include enough data to find out where the material was used.
Mon, Jan 13, 2014 at 3:43:37 PM | Render Problems
#17
Arch117
Thankyou I Renamed the layers and created some new ones that I applied to the objects their appearing fine now.
Render problems
Tue, Apr 8, 2014 at 11:05:28 AM
shader and render colour problems
Tue, Sep 15, 2009 at 5:58:17 PM
REVIT ARCH 2011 render problems
Fri, Sep 16, 2011 at 2:04:13 PM
Render problem
Thu, May 30, 2013 at 12:37:29 AM
RAC 2010 RENDER PROBLEMS
Mon, Sep 14, 2009 at 4:24:40 PM
Page generation time: 0.3639
