Forums >> Revit Building >> Technical Support >> 2014 - Revisions on Sheet dialog box is broken
Thu, Nov 14, 2013 at 4:10:21 PM | 2014 - Revisions on Sheet dialog box is broken
#16
tbryanm
1 Stars: 1 Votes
gbiallas5728, Not sure how I arrived at this, or even if the genesis of your issue is the same. But my title block was created in R12 by the office IT/CAD "expert" (who has since departed) and the Revision Schedule used what appears to be lables. Not sure how that worked but it did and don't really care at this point. I created a new Revision Schedule by doing the following....
1. Open your title sheet .RFA file
2. Go to the VIEW tab and click on REVISION SCHEDULE
3. Set your fields and click ok
4. Sort, Format and customize the appearance just as you would a door or wdw schedule and then draq/insert into the sheet.
As with just about every Revit task you will need to trial and error it to death to get it to fit within your titleblock. Only took me about an hour. Which is better than the 8hrs that it took to create a door tag.
@WWHub Note the solution based response. No conjecture. No showcasing. Just a humble "here's what I did and it worked".
Mon, May 19, 2014 at 3:59:36 AM | 2014 - Revisions on Sheet dialog box is broken
#17
bradstrauss
I too am getting this issue. Searching around other forums suggests this has happened to others and is a bug.I recently rebuilt our template without realising this bug was in it and as such, all projects created with it will contain the bug...
The template was built from saving off a new revit file from a generic <none> template (the issue exists even here). I recently upgraded Revit 2014 to service pack 2 and creating a new project as above does not have the issue.
As far as I know, once the project has the bug, that project is stuck with it.
I will have to create a new template without the bug in it.
Looks like there might be a few workaround titleblocks in the meantime.
revisions display issue [ 1 2 ]
Mon, Sep 15, 2014 at 3:23:27 PM
15
Revit Dialog Box When Opening
Thu, Feb 25, 2016 at 9:32:50 PM
Populate Revisions in Title Block
Wed, Nov 13, 2013 at 2:20:01 PM
2017- adding mutliple revisions to sheet index
Mon, Apr 15, 2019 at 3:29:19 PM
REVIT RENDER QUALITY SETTINGS DIALOG BOX
Thu, Dec 18, 2008 at 11:04:04 AM
Page generation time: 2.7795
