Forums >> General Discussion >> Revit Project Management >> Question about stair openings
Fri, Jan 25, 2013 at 11:22:44 AM | Question about stair openings
#16
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Right now my floor opening is the lenght of the stairs, 13'-9" for the floor and 13'-9" for the cieling.  In 3D view it seems like there is plenty of head clearance. I can see the door on the 1st floor. And the stair railing is 3 feet in height from the top of the 2nd floor.
Fri, Jan 25, 2013 at 11:28:04 AM | Question about stair openings
#17
Our code calls for the minimum clearance to be measured from the nose of a tread vertically - not parallel to the slope.  That clearance is to the complete structure - floor and ceiling so plan accordingly.
BTW, you can just add a vertcal RP in section that you can then edit your sketch to in plan.
Edited on: Fri, Jan 25, 2013 at 11:28:58 AM
Fri, Jan 25, 2013 at 2:49:44 PM | Question about stair openings
#18
revituser24
revituser24 Avatar
3 Stars: 1 Votes
what is a "RP"? and how do I "add a vertical RP in section"?
Sat, Jan 26, 2013 at 5:19:58 AM | Question about stair openings
#19
4 Stars: 205 Votes
"RP" is "Reference Plane"
Curved Stair Question
Mon, May 7, 2007 at 2:10:41 PM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:46 PM
Very Simple question regarding openings
Sun, Jan 2, 2011 at 8:18:11 PM
Monolithic Stair Question
Thu, May 26, 2011 at 7:14:39 AM
OPenings through multiple walls?
Mon, May 24, 2010 at 4:48:54 PM
Page generation time: 0.3513
