Forums >> Revit Building >> Technical Support >> Dimension Text
Sun, Jul 6, 2008 at 9:47:43 PM | Dimension Text
#16
clinard79
Make a new dimension type with a "blank" text. When you make a dimension string then none of the dimensions will show up, then you can just use text to type whatever you wantSmile
Mon, Jul 7, 2008 at 3:19:59 PM | Dimension Text
#17
JOELSOARS
Revit Arch 2009 has fixed that problem.
You can pick the dimension then pick the dimension text and change it through a "Dimension Text" window with many other options.
The Cadpounder
Tue, Jul 8, 2008 at 7:02:09 AM | WWHub
#18
notagain
notagain Avatar
4 Stars: 1 Votes
Quoting WWHub from 2008-07-03 13:34:21
"I have been burned too many times in AutoCAD by people who simply over-rode a dimension rather than drawing it correctly. "
It should always be drawn to scale...especially if you have a model deliverable, which I do...we have very strict cad standards and not drawing something correctly will be picked up by the other disciplines.
Still there are conditions and details where you need to over write the dimension...for example...I know I have a girt line, but probably won't know where it is at until it's erected (we do a lot of design build). I would be great if this detail was dynamic
there are cases...for example...may be I don't want to give a louver opening dimension, I just want to say "Opening"
 gotta go...that's all for now
I really want this to work...some good things some bad
Tue, Jul 8, 2008 at 9:15:07 AM | WWHub
#19
notagain
notagain Avatar
4 Stars: 1 Votes
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
REMOVING DIMENSION TEXT
Wed, Jul 2, 2008 at 9:31:23 AM
Page generation time: 3.4685
