Forums >> Revit Structure >> Technical Support >> Inserting a 2D Component into a new project sheet
Thu, Jun 21, 2012 at 3:04:25 PM | Inserting a 2D Component into a new project sheet
#16
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You are right you will not be able to add annotation with arrows in your family.  If you are trying to convert all of your offices old details into Revit your best option is to not put them into families.  You should create a new project and create a new drafting view for each detail and keep ALL of your details in that one project (you can add annotation with arrows in a project).  You will name each drafting view differently (the name is what the detail is of) and this way you will have all of your details in one area.  Once you need a detail in a project that you are workin on you will go to the INSERT tab of the project you are working in>INSERT FROM FILE pulldown>INSERT VIEWS FROM FILE and seach for the location of the project that has all of your details in and it will bring up a dialog box with all of the names of your details that you have drawn and you can check the box to bring in the details that you want.
Thu, Jun 21, 2012 at 4:56:07 PM | Inserting a 2D Component into a new project sheet
#17
ArchCheerios13
Still having problems inserting the detail component family into the drafting view then into the sheet. If can please give me a step by step process i would appreciate it. Thanks
Thu, Jun 21, 2012 at 5:00:04 PM | Inserting a 2D Component into a new project sheet
#18
ArchCheerios13
sry teafoe5 didnt see your response till now, i will have to try that process, i just thought it would be easier to save all the different details as a family then just insert it them into a project sheet whenever i needed. I guess Revit wont allow me to do that. Ok i will try your process and get back to you. Thanks
Thu, Jun 21, 2012 at 5:05:11 PM | Inserting a 2D Component into a new project sheet
#19
ArchCheerios13
I opened up a new project and a new drafting view, i set my scale to 1/2" = 1', and tried importing the cad file and it wont show up in the view . . .
Thu, Jun 21, 2012 at 5:09:18 PM | Inserting a 2D Component into a new project sheet
#20
ArchCheerios13
Got it to work! just had to play with scale! . . .
Fri, Jun 22, 2012 at 8:39:40 AM | Inserting a 2D Component into a new project sheet
#21
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Good Luck!  It can be a tedious process taking the YEARS of compiled CAD details and turning them into Revit but it is very worth the time and effort.  This is a great forum to ask questions you just cannot find an answer to, just make sure you do a little research on your own first or someone is going to tell you to just look in your help Winking
inserting floor plan into sheet
Tue, Feb 28, 2006 at 7:17:46 PM
Inserting Component
Thu, Mar 4, 2010 at 10:46:39 AM
inserting detail component into a beam family
Thu, Feb 22, 2018 at 6:55:27 AM
A guide to inserting profiles?
Thu, Dec 20, 2007 at 4:17:44 PM
Component with text?
Wed, Jun 6, 2007 at 5:26:12 PM
Page generation time: 0.6460
