Forums >> Community >> Newbies >> Rendereing
Search this ThreadSearch this Thread | Page 2 of 3 | << Previous 1 | 2 | 3 Next >>
Mon, May 21, 2012 at 3:52:25 PM | Rendereing
#16
Paulinak73
Thah is exactly what I' ve been doing...Carpet shouldnt be glossy...I played with wood, concrete etcetc..Vry frustrating, since the perfect rendering came out nice.
Mon, May 21, 2012 at 3:59:57 PM | Rendereing
#17
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
AHHA.
Paint.  Is it painted?  Use the remove paint tool!
Mon, May 21, 2012 at 4:24:10 PM | Rendereing
#18
Paulinak73
Hold on, what paint  do you mean? Under my "materials"?
Mon, May 21, 2012 at 4:30:57 PM | Rendereing
#19
itsmyalterego
4 Stars: 16 Votes
There's a "paint" tool under the modify tab.  If a surface is painted, it will override any changes that are made to the underlying materials.
It can be a real pain in the curse to figure out sometimes.  But if you don't remember painting it... maybe that's not the answer.  But I would wager it is.  There's a little dropdown arrow on on the paint icon, that allows you to use the "remove paint" tool.
It's in the modify tab, geometry box, the checkered circle icon pointing at a cube.
Mon, May 21, 2012 at 4:37:13 PM | Rendereing
#20
Paulinak73
Do i need to go to the main menu and go under 'Modify"/ Or you are talking about the properties box?
Mon, May 21, 2012 at 4:48:14 PM | Rendereing
#21
itsmyalterego
4 Stars: 16 Votes
On the main menu.  Nothing selected, nothing being edited.  It's one of the general tools up there with "edit wall joins" "cut geometry", etc.
Find the remove paint tool, and then see if the floor highlights when you hover over it.  If it does--then click to remove any paint.
Paint is used to override materials on ANY face.  It is a very dangerous tool--because there is no way to mass-unpaint.  I had a former coworker paint literally hundreds of surfaces in a project one night--he stayed there until midnight to do it.  I didn't realize what he'd done until backups got overridden... it took me days to track down all of the surfaces that had been overridden.
Mon, May 21, 2012 at 5:07:08 PM | Rendereing
#22
Paulinak73
Mon, May 21, 2012 at 5:10:31 PM | Rendereing
#23
itsmyalterego
4 Stars: 16 Votes
main menu.  not properties.
Edited on: Mon, May 21, 2012 at 5:14:07 PM
Mon, May 21, 2012 at 5:27:07 PM | Rendereing
#24
Paulinak73
Took the paint off...same thing, the reflection is still there. It looks just like water ...instead of the carpet I get a mirror reflection of walls and windows... Sad glitch? Maybe i can send you teh file or I dont know if this is legal here on RC.
Mon, May 21, 2012 at 5:52:34 PM | Rendereing
#25
itsmyalterego
4 Stars: 16 Votes
If it's a very small project file, you might be able to post it.  If it's 10-12MB, send it to itsmyalterego@gmail.com and I'll take a quick look at it.  Now I'm pretty curious what's going on.
Mon, May 21, 2012 at 6:01:55 PM | Rendereing
#26
Paulinak73
I will send it. It's large, two story building. mainly in CAD, Im just learning REVIT using this project.
Mon, May 21, 2012 at 6:20:19 PM | Rendereing
#27
Paulinak73
sent. let me know if you got it !
Mon, May 21, 2012 at 6:42:12 PM | Rendereing
#28
itsmyalterego
4 Stars: 16 Votes
Got it.
It's the Topography.  the topography is perfectly flush with the floor level, so although you have everything set perfectly with your floor (non-glossy, correct wood material, etc) -- the topo is also trying to render.  And guess what!  It's set to 100% reflective mirror.  Defauting to the material "$1163_Barracks\wood01" Change the topo to "Site - Earth", and... either drop it all down an inch or two, or split the surface to cut the building footprint out of the topo.
If you're mostly interested in renders, leaving the topo surface burried an inch or two within the floor is a quick and easy solution.
PS.  Nice bookcases Winking
Edited on: Mon, May 21, 2012 at 6:47:33 PM
Tue, May 22, 2012 at 10:09:22 AM | Rendereing
#29
Paulinak73
Thanks, I will try to do what you  suggest and will let you know ! Smile
Tue, May 22, 2012 at 11:11:51 AM | Rendereing
#30
Paulinak73
I did changed the topo to site-earth, but dont know how to do the rest, can you show me the window I plug those number in?
rendering light source
Mon, Dec 19, 2011 at 3:21:42 PM
Renderer Plugin for low end school laptop
Tue, May 13, 2014 at 6:06:26 AM
"Render" button greyed out
Mon, Feb 15, 2010 at 1:57:13 PM
Revit VS. ADT2005
Mon, Apr 4, 2005 at 9:23:20 PM
Page generation time: 0.8457
