Forums >> Revit Building >> Technical Support >> 2011 change material color
Tue, Mar 13, 2012 at 8:10:00 AM | 2011 change material color
#16
In the material editor, edit the material - change it from image to wood.  You will still have the siding but now you will be able to change the two wood colors to create the graining and colors you want.
Sat, Aug 31, 2013 at 8:46:22 AM | 2011 change material color
#17
1ma1
Via http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Material-color-change/td-p/2854236
Try-
Duplicate the material youre trying to edit then...
Under Render appearance there is a section "render appearance based on..."  Click "replace"  then scroll to default and select "generic"
Under "color" select the arrow to the right of the swatch, select "edit color" then "define custom color"
       Create the color you want
Scroll down and check the box in front of "bump"  then load the texture used for the corrugated metal.  Adjust the amount of bump until the desired amount is achieved.
I've attached a jpg of a material I built like this.
Hope this helps
2011 revit: selected material/color does not show up
Tue, Jun 8, 2010 at 3:41:55 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
change material color in linked file
Tue, Oct 5, 2010 at 9:09:57 AM
How do you change the material and color of a download?
Tue, Aug 6, 2013 at 7:31:46 AM
Change material and or color on railings
Thu, May 5, 2016 at 9:30:10 AM
Page generation time: 1.5999
