Forums >> Revit Building >> Technical Support >> Taging
Thu, Aug 26, 2010 at 7:46:55 AM | Taging
#16
nirim
5 Stars: 12 Votes
WYS1WWYG I am not totally sure but it seems to me that the solution of dgcad above is the same. Without any connection, thanks for your reply regarding the render material dialog box,it's probably going to be the solution .
nirim
Thu, Aug 26, 2010 at 4:53:24 PM | Taging
#17
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
yes reinstalling the program most likely will be the solution..
also keep in mind that when ANY software program behaves
strange like that- there is most likely serious corruption at the
foundation of the program.. and when you also suspect there
is serious corruption with your operating system- you
need to reinstall that too.. one should always
keep all of their work saved to an external drive
at all times..
that way you can quickly wipe everything off
your hard drive if you need to- and put revit
AND the OS back on the drive CLEAN.. windows 7
is especially made for quick and easy reinstalling..
hardware is nearly never the problem..
3D taging
Wed, Jul 1, 2009 at 4:00:00 PM
Default Category Tag Question
Sat, Aug 15, 2015 at 8:56:00 AM
detailing by tag(taging beam system)?
Tue, Aug 21, 2007 at 3:09:54 AM
Annotation Object Styles
Thu, Dec 17, 2009 at 9:21:42 AM
Rooms does not "work" on ground floor but works on 1st. floor
Mon, Dec 26, 2016 at 7:06:41 AM
Page generation time: 0.0492
