Forums >> Revit Structure >> Technical Support >> Revit Structure 2010 won't start!!! Help!!!
Tue, Sep 7, 2010 at 11:19:23 AM | Revit Structure 2010 won't start!!! Help!!!
#16
GBAT
This fix works on Revit Structure, MEP, & Architecture as well in the 2010 & 2011 release.  The official Autodesk solution to the Revit Won't Run or Start Up issue is to delete the WSCommCntrData.xml file in the folder listed above.
Greg Bates
ManagedDesignInc
www.ManagedDesignInc.com
Wed, Sep 8, 2010 at 10:54:03 AM | Revit Structure 2010 won't start!!! Help!!!
#17
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I opened a support ticket at Autodesk and the help that I got was less than satisfactory. This is what I ended up doing.
Just a follow up for Chris Aquino
Autodesk support team.
My products seemed to start doing the same thing again. I got a tip from RevitCity forum said to
“delete the file WSCommCntrDATA.xml found at C:\documentsand settings\user\localsettings\applicationdata\autodesk\revitversion\enu\components\webservices”
Guess what , it seems to work. There appears to be an internal conflict within the Autodesk system you guys should fix. Several other people have reported this problem.
If you think that I have made a mistake to delete that program or if you can let me know what it’s purpose is I would appreciate a reply.
Thank you
Steve Carnes
Mon, Apr 18, 2011 at 6:45:20 AM | Revit Structure 2010 won't start!!! Help!!!
#18
brenb84
This worked perfectly!!! OMG THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mon, Oct 8, 2012 at 11:20:42 PM | Revit Structure 2010 won't start!!! Help!!!
#19
Burgo
Deleting "WSCommCntrData.xml" worked for me.
To locate "WSCommCntrData.xml" to delete it see http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15145616&linkID=9243099&CMP=OTC-RSSSUP01
this should work for all disciplines of Revit 2010 (Architecture / Structure / EMP) on windows XP and Windows Vista / Windows 7.
Revit won't start again (i have to restart) [ 1 2 ]
Thu, May 26, 2011 at 6:07:37 PM
20
Revit 2010 won't start up
Tue, Sep 28, 2010 at 4:32:52 PM
revit won't start
Thu, Nov 3, 2005 at 10:50:45 PM
Unable to start robot analysis structure (HELP NEEDED)
Tue, Apr 29, 2014 at 10:11:09 AM
Metalic Structure in Revit Architecture
Fri, Dec 3, 2010 at 1:10:10 PM
Page generation time: 3.0510
