Forums >> Revit Building >> Technical Support >> Change Line Color
Tue, Sep 8, 2009 at 9:05:59 AM | Change Line Color
#16
MARS1276
1 Stars: 1 Votes
As to your original posted question, I am not sure anything can be done about the issue of references being gray appearing too difficult to see.
Like yourself, I too find using the black background to be more beneficial.  I have seen many 3D programs just watching "behind the scenes" stuff on movies that show black or grey backgrounds.
Eye strain IS an important issue.  Wether people recognize it or not, eye strain (for me anyways) is mentally stressing.
As for prints go, I work with a black background but my image and sheet layouts still appear white with black lines.  So I have no trouble at all distinguishing what the print will look like before it goes to the plotter; albeit, sometimes the lineweights are a little tricky to discern until it IS printed.
Another reason I prefer the black background... my disablility.  I have epilepsy which, with medication, is for the most part kept in check.  But all day I am working on the computer and under bright lights.  So this creates a visual strain for me in particular.  Not to mention my kitchen has the same type of lights.  So when I am working on the computer for long hours at a time I do have some minor problems, same for at home and when working with my laptop.
Again, see my comment about light being mentally stressing.
And think about the colors.  Monitors generally use Red, Green, and Blue colors to show the various colors you are seeing.  White is a combination of all colors seen.
Of those colors, studies have shown that yellow can lead to headaches and red can lead to other effects that may be, to some, undesireable.  I have known others that cannot view the color red without headaches or suffer seizures of some minor sort.
So there IS some merit to what WYS1WYG is stating about eye strain.
And I understand I may be an exception in this particular case, but some of the reasons I have explained do pertain to a majority of people.
But that is why I prefer using a black background.
Fri, Apr 2, 2010 at 11:45:58 AM | Change Line Color
#17
missgayley
missgayley Avatar
jumping in late - but i'm not sure how literal one has to be with WYSIWYG
the line thickness visibility on/off feature is still going to show me what i'm getting and i don't need my "paper" to look white to know that it's going to be white......
color doesn't equal line thickness like it did in cad ~ however, i want to glance at my drawing and know instantly what lines are purlins, walls, ledgers etc - so yes, i have gotten rid of many of the white line definitions... colors abound!  i can select the line i want without tabbing thru 6 selections first.
in the end, i don't see it being a cad vs. revit issue - more of a 'personal comfort' thing.
Fri, May 10, 2013 at 11:03:39 AM | Change Line Color
#18
sllana
5 Stars: 2 Votes
Anyway...you can change that dim color for selected objects in options-->graphics .
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Change color of hatch?
Tue, May 24, 2005 at 6:10:43 PM
Change color on linked workset
Tue, May 16, 2017 at 6:42:49 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
how to change the default ground color ?
Thu, Feb 26, 2009 at 8:24:47 PM
Page generation time: 3.4509
