Forums >> Revit Building >> Technical Support >> Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
Mon, Jun 1, 2009 at 5:56:09 PM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#16
lunchtrayrider
3.5 Stars: 7 Votes
in your cataylst ontrol center try these settings under the 3d graphics settings:
 anti-aliasing: use application settings
 adaptive anti-aliiasing: not enabled
 anistropic filtering: use application settings
 catalyst ai: (standard works for me, you could try it disabled)
 mip-map i have set to quality
 wait for vertical refresh should be off
Tue, Jun 2, 2009 at 12:42:25 PM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#17
jche
thanks lunchtrayrider for looking into it - unfortnunatelly messing with catalyst didn't do much. I'm about to throw in an nVidial card into the mix just for sh.ts and giggles and see what happens.. I'll post my feelings about it in a near future..
Tue, Jun 2, 2009 at 4:11:20 PM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#18
lunchtrayrider
3.5 Stars: 7 Votes
dang im out of ideas.
Wed, Jun 3, 2009 at 9:47:47 AM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#19
jche
update: found a basic nVidia card - GeForce 8300 gs, in one of our computers, plugged it into my machine and it WORKED! I can tell it's slower than all the newer and beefier ATI cards I tried but the thing works - things don't vanish randomly from the PDF's and prints and also so far no crashes and sh.t like "could not draw contents of this window therefore it will be closed".. conclusion: someone (either Autodesk or ATI) has to fix their stuff.. the program or the drivers but before then no DirectX in Revit for ATI cards. (or so it seems for my 4 computers)..
Wed, Jun 3, 2009 at 10:25:02 AM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#20
lunchtrayrider
3.5 Stars: 7 Votes
yea sounds like a driver problem for ati then. no good.
Tue, Jun 9, 2009 at 1:06:58 PM | Revit 2010 - DirectX - and elements disappearing from scrin, pdf's and plots
#21
missgayley
missgayley Avatar
since you've solved your problem ~ i'll just add this for others that may come across the problem of missing lines on a plot...
for us, it's our poor, ancient, plotter (after all, it's 5 years old now!!)
we've had to switch to "in computer" memory instead of "in printer"
i'm getting stupid "error drawing window" messages (structure 2010) and the only autodesk suggestion is to disable the graphics acceleration.   it's already disabled. so i guess i need to look into this graphics driver stuff.
blah.  a true love-hate with computers here.
Text Background Mask Disappearing in PDF's (Revit Architecture 2009)
Thu, Feb 12, 2009 at 1:29:29 PM
Disappearing Elements
Thu, Apr 29, 2010 at 6:52:18 PM
plotting pdf's??
Sat, Jul 15, 2006 at 7:36:12 AM
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:07 PM
window frames disappearing
Thu, Aug 18, 2005 at 3:05:08 PM
Page generation time: 1.5967
