Forums >> Revit Building >> Technical Support >> Importing Autocad background - Revit Model to exceede 2 miles across
Mon, Jun 29, 2009 at 5:44:40 AM | Importing Autocad background - Revit Model to exceede 2 miles across
#16
sagarkagathara
sagarkagathara Avatar
@ apanico
 Scale? Yes, use the 'Resize' command on 'Modify' tab.
Mon, Jun 29, 2009 at 8:27:36 AM | WWHub
#17
RevitSVA
RevitSVA Avatar
Quoting WWHub from 2009-06-29 05:34:35
This problem is addressed in the premier issue AUGI/AEC EDGE.  DWG improrts with coordinates (before scaling) longer than 10 digits may be truncated to 0 and become corrupt.  They also say that entities furtur than 2 miles apart (after scaling) may cause accuracy issues and are not allowed.
The solution - subdivide into smaller files.
"WWHub
Thanks for directing me into that direction... The issue gives very usefull reading tips etc...
However the solution for the above mentioned problem is rather a poor one to say the leas ... I really hope they are addressing it in the next fix!
Further we are currently using the import into 2009 and then converting it to 2010 which suites us the best as we dont want to waist time in AutoCAD splitting up Civil drawings.... And we do work on bigger scales or landscaped Environments which require us to have a site bigger than 2 miles accross... holding thumbs for the Service pack!
Fri, Aug 7, 2009 at 5:28:42 PM | Importing Autocad background - Revit Model to exceede 2 miles across
#18
Slavedrafter
I am also having this problem and I know my drawing is not possibly more than 2 miles across.  I'll try the import to2009 trick, but I agree with other posters that this is a wasteful and frustrating problem.
Sun, Aug 9, 2009 at 5:11:16 PM | Importing Autocad background - Revit Model to exceede 2 miles across
#19
CavCORP
agreed very unnecessary problem
how i fix this problem now is, i open the cad file in AutoCAD, then 3d orbit around. it shows a couple line layers far lower then the drawing it self so i delete them. imports perfect
Sat, Jan 16, 2010 at 8:41:38 AM | Importing Autocad background - Revit Model to exceede 2 miles across
#20
nathant
I had the same issue moving from Revit 2009 to 2010 (recieved the same 2 mile error message in Revit 2010 but not in 2009). Once I exploded all objects in my cad file, and then purged, everything came into Revit 2010 OK. I wasn't even working with a site plan, it was only a 1.1 mb file of a building plan from Auto Cad. Thanks for everyone's help.
Sat, Apr 17, 2010 at 7:29:52 PM | Importing Autocad background - Revit Model to exceede 2 miles across
#21
Hicko
Cheers Mr Spot.... you the bomb.
Thanks from Australia.
Having trouble import Autocad files into Revit 2010
Tue, Jun 9, 2009 at 8:55:02 AM
Linking AutoCAD Site Contour missing 2014
Wed, May 27, 2015 at 7:56:32 AM
Importing / Modifying Topo from AutoCAD
Thu, Feb 16, 2012 at 11:14:10 AM
superimposing model on a photo or adding background to a model
Sat, Nov 29, 2008 at 1:40:22 AM
Importing a 3d autoCAD model - preserve individual 3d elements in model
Wed, Apr 21, 2010 at 1:29:11 PM
Page generation time: 1.6892
