Forums >> Revit Building >> Tips & Tricks >> 2010 Ribbon Customization...What are you doing?
Thu, May 21, 2009 at 8:56:21 AM | 2010 Ribbon Customization...What are you doing?
#16
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
You can use 3 letters.  I didn't know that.  Well you learn something everyday.
This would be perfect for the tools they split into two with 2010 now.  For example, Mirror is now only defaulted to picking an axis and you have to select a different tool to draw the axis.  Even though I set the two up to 'MM' and 'MX'.  Tools that have been split up could now be three letter works, i.e. 'MM' and 'MMX'  That way it's still the same command with another letter.  Just an idea of how I might use three letter commands.
Thanks for the info.
Denver, CO
Revit Architecture
Thu, May 21, 2009 at 1:22:54 PM | 2010 Ribbon Customization...What are you doing?
#17
lorne ... as with all things that are ribbon... you have to learn where to look... there is a pull-down to the right of the mirror that gives you the option of pick a line or draw one....
Thu, May 21, 2009 at 2:55:34 PM | 2010 Ribbon Customization...What are you doing?
#18
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
WWHub, yea I konw where it is, I am getting used to the Ribbons (althought I don't like them).  So that is why I use shortcuts.
I was merely just giving an example of how one could use the three letter shortcuts.  Mirror is one I came up with.  I am used to using the MM command then selecting the drawing option rather than starting on a different tool.  But again this was just an example.
Thanks,Lorne
Denver, CO
Revit Architecture
Tue, May 26, 2009 at 3:23:30 PM | gprakash
#19
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting gprakash from 2009-05-21 07:37:29
Eventhough it is meant to be shortcut keys, you can also use three keys if you wish. For example, if "CS" is already assigned for CREATE SIMILAR, you can use "CSM" for CHECK MEMBER SUPPORT.
If you run out of alphabets in Keyboard shortcuts, numbers can also be used. (I am sure all of you know!!)
I prefer using keboard shortcuts as much as possible.
So I tried this for Room (RM), Room Tag (RMT), and Room Separation Line (RMS).  Turns out for Room (RM) it doesn't work for just RM, you have to press enter to end the shortcut.  Which makes sense but is kind of annoying.  Just an FYI for those trying this method.
Lorne
Denver, CO
Revit Architecture
Wed, May 27, 2009 at 12:03:45 AM | 2010 Ribbon Customization...What are you doing?
#20
gprakash
Lorne, I agree that might be annoying to press ENTER after two letters everytime. Since I have practised by hitting ENTER on the numeric pad (desktop) with the right thumb by the side of the mouse, it is easier for me being a right hander!
Thu, May 28, 2009 at 9:55:29 PM | lorne17
#21
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Quoting lorne17 from 2009-05-08 09:25:59
Well I haven't done too much to mine, but I have right clicked on switch windows(under view tab) and put that on my quick access toolbar.
I have more customized my keyboard shortcuts.  I have that .txt file open all the time and whenever I run into a shortcut I want I add it.  My shortcuts in 2009 were pretty extensive and I lost them all Sad  Oh well, now they will be better than before.
I am bummed you can't customize the ribbons as extensively as AutoCAD.  Create custom ribbon panels, etc.  Maybe int 2011.
Please send me to a link of a form that shows how to set up keyboard shortcuts, or just tell me. our firm has just switched over to revit and alot of the older guys are missing there keyboards shortcuts from CAD. so this would be of great help to many people.
J. Allen Ball
Fri, May 29, 2009 at 12:29:24 AM | 2010 Ribbon Customization...What are you doing?
#22
gprakash
Please see the threads  http://www.revitcity.com/forums.php?action=viewthread&thread_id=4601 and http://www.revitcity.com/forums.php?action=viewthread&thread_id=11860
"When you make custom shortcuts, it is a good idea to run a search for the shortcut to make sure it is not already taken" - Thanks Revitkid.
After assingning shortcuts and saving the file, you need to restart the Revit program to allow shortcuts to work.
Fri, May 29, 2009 at 8:58:12 AM | 2010 Ribbon Customization...What are you doing?
#23
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Thanks man!
J. Allen Ball
Fri, May 29, 2009 at 10:06:34 AM | 2010 Ribbon Customization...What are you doing?
#24
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Allen,
Did you get your shortcuts working?  I can help if you have questions.
I have also been trying to figure out a way to link the .txt file to an excel sheet so when it's updated so is the excel sheet.  So I can print a cheat sheet for my coworkers.  But the excel forums aren't as good as Revit City, hehe.  So I just gotta wait patiently.
Unless someone here knows how to link it?  I know how to import it but there's not linkage?
Denver, CO
Revit Architecture
Fri, May 29, 2009 at 10:26:53 AM | 2010 Ribbon Customization...What are you doing?
#25
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I just found this, which seems really great:
http://forums.augi.com/showthread.php?p=978865#post978865
Easy enough to open, add shorcuts then copy columns A&B into the text file and save.
Denver, CO
Revit Architecture
Mon, Jun 1, 2009 at 11:40:39 AM | 2010 Ribbon Customization...What are you doing?
#26
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Very nice Find Lorne!!! ya i got it all working, thanks for the help.
J. Allen Ball
Wed, Jun 3, 2009 at 1:59:47 PM | 2010 Ribbon Customization...What are you doing?
#27
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I dont know if anybody knows this but i just found it out. If you are wanting to have seperate categorys in your ribbon for different types of elevations, such as interior, or exterior. You can take your normal elevation tag and duplicate it and call it interior elevations, and it will automatically make a new category in your ribbon for interior elevations. same thing goes for if you want to seperate sections, into building sections and wall sections.
 now does anybody know how you could apply this same concept into plans?
J. Allen Ball
Wed, Jun 10, 2009 at 1:28:21 PM | 2010 Ribbon Customization...What are you doing?
#28
MARS1276
1 Stars: 1 Votes
AllenBall,
A little confused as to how you are doing this... Are you talking about applying this change to the RIBBON or the PROJECT BROWSER...?
I know the Ribbon's View Tab has on the Create panel the Elevation tool with the drop-down choice between ELEVATION and a FRAMING ELEVATION.  Is it here you are saying you could add an interior elevation choice?
In either case, I am not sure how you are doing what you suggest can be done.  Is there another manner by which you could explain?  I would like to know what it is you are meaning to do, even if I feel I do not want to implement it; I would still like to see what's capable of being done with customizing Revit's Out-of-the-box tools.
Ribbon for Revit
Sat, Aug 29, 2009 at 2:09:53 AM
Revit 2009/2010 Autostart shortcuts (Revit Ribbon)
Sun, Aug 9, 2009 at 12:21:31 PM
Revit 2010 UI Problem
Wed, Jan 13, 2010 at 1:45:49 PM
Missing Element Properties Ribbon
Fri, Aug 20, 2010 at 2:43:20 PM
Easy Way to Edit Shortcut Keys for 2010
Tue, Aug 18, 2009 at 12:37:10 AM
Page generation time: 0.6372
