21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Render Calculation Error?
what was this thread about anyway- oh yeah rendering.. starting two years ago i was one of many who asked in the autodesk forums why revit had such a crappy rendering engine.. lol finally they did something about it.. MentalRay is so awesome.. it still amazes me.. now i can actually see my models..
1 Posts No Rating |
Hey guys, I'm having the exact same problem as kripple51. I'm hoping that since this was posted about a month ago that someone found a solution. I also did update 3 for Revit 2009. System stats: Vista Home Premium, Core 2 Duo T7500 @2.2GHz, 3 GB RAM, Total Virtual Mem 6.19GB Availiable Virtual Memory 4.29GB. I went as far as to DL Revit 2010 but along with other issues I got the same problem. The only time my rendering operated as normal is when I deleted part of my massing. This is obviously an undesirable solution. Any help will be appreciated. Thanks
38 Posts No Rating |
I am having the same problem, I am rendering an aerial site plan, there is no sky visible in the rendering, could this be part of my problem? I am also running vista, but have done tons of renderings with no problems, just the two aerial shots I need to render, renders about 10% and then gives me the errorr "Unknown error during rendering calculations. The rendering operations will be cancelled."
6 Posts No Rating |
i am not able to reder anything mine is a large building.. can you give me the link to the update with which i can render? i need to get rints tonight...so please reply ASAP!
You have not told us anything about your system or your problem. This thread was from 2009 and a completely different render engine.
Without knowing anything more, I suggest you use ccleaner to clean your temp directory. A full temp directory often causes render problems.
Stair Material Takeoffs - Volume Calculation Error when Painting |
Tue, Dec 10, 2013 at 7:45:46 AM
Error: Revit was unable to render the view due to an unknown error. |
Mon, Apr 28, 2014 at 3:32:17 AM
Render Error - "Unknown Error during Rendering Calculations" |
Fri, May 1, 2009 at 1:52:23 PM
help: why do I get a server error when I try to render revit in iCloud?? |
Tue, May 20, 2014 at 12:58:46 PM
Error in RAC 2009-RENDER |
Thu, May 22, 2008 at 4:28:46 AM
