Forums >> General Discussion >> Wishlist >> PAD IMPROVEMENT
Fri, Feb 27, 2009 at 4:13:01 PM | PAD IMPROVEMENT
#16
4 Stars: 205 Votes
Well to solve your problem right now i think i JUST update because 2010 only come march/april...
Good luck...
Fri, Feb 27, 2009 at 4:56:30 PM | PAD IMPROVEMENT
#17
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I know exactly what you are facing with the Pads and the small dirt walls that can be created. Very frustrating. See the attached for an alternate for street work somewhat time consuming but very accurate.
Thu, Mar 5, 2009 at 7:41:10 PM | PAD IMPROVEMENT
#18
twhisker
2.5 Stars: 5 Votes
I hate pads as well.  i am trying to JOIN a wall to a pad so that the concrete curb in the wall and the concrete pad will join and look as one.  I can do this with floors.  is it pads that you cannot join or cut geometry?  RAC2009 SP3.  thanks.
Revit Architecture 2010
Fri, Mar 6, 2009 at 6:42:09 AM | PAD IMPROVEMENT
#19
dfitzladdy
5 Stars: 3 Votes
twhisker,
No, i'm not trying to cut geometry or anything.  I'm just drawing, for an asphalt street.  When I first discovered pads, I was creating all aspects of the street - curb, gutter, sidewalk, and the pavement.  This is when I first encountered the "pad overlap" problem, so I eliminated my pads down to one instance - the street.  That worked for a couple of projects, but I recently received the message again despite the fact that I only had a SINGLE pad, and it wasn't overlapping itself anywhere, AND i wasn't even working on the pad.
mbsteve,
thanks for your suggestion.  That's a very good idea.  I haven't yet had to actually used a sloping topo, since none of my clients have requested a 3D model of the site. so, my need for pads is completely absent, regardless of my frustrations with them.  When the time comes for me to model topography, i'll use your suggestion. Thanks!
Tue, Mar 10, 2009 at 5:19:08 PM | PAD IMPROVEMENT
#20
grebiwnotnerb
3.5 Stars: 12 Votes
I hate pads aswell. i'm waiting for 2010 to see if they've fixed the problem, but you are not crazy, pads are.  I know tons of people that encounter this same problem when doing curbs and what not.  The "pads cannot overlap" error haunts my dreams. The picture given on the first page of posts proves nothing seeing as how the pads do share an edge, but they are not deep enough to touch one another.  Try deepening the pads so that the common edges touch, and you will get the error.  This really needs to be fixed! I'm hoping for 2010.
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Cannot choose edge of a pad in Revit 2010
Sun, Feb 21, 2010 at 5:16:33 AM
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Existing pad not cutting topography properly.
Mon, Jun 7, 2010 at 7:27:40 AM
Page generation time: 0.0573
