Forums >> Revit Building >> Technical Support >> REVIT Architecture 2009 Basic Architectural Convention question
Tue, Oct 21, 2008 at 8:19:58 AM | REVIT Architecture 2009 Basic Architectural Convention question
#16
MARS1276
1 Stars: 1 Votes
  If I am understanding your complete post, it sounds like you have the same issue and have found a nice work-around.  I have noticed that you can make you're own line types.  I'm wondering if you can create multiple line types of the same thickness and type (solid) but give each a different line weight.  So, if I'm following what you have said; I could make a solid line type be a weight of 0.7 and call it concrete block, another to be a weight of maybe 0.3 (I don't know) and call it stud wall... so on so forth.
I will definitely have to look into that.
 Also, in your template, you mentioned using it to show text styles used in your projects.  We too have a specific text style we use.  Is there a way to make said template apply to tags and labels as well without having to change the actual text within the 'host' family?  If that's the case I beg you tell me how.  I can't tell you how many labels and symbols I have redone and saved just to show the text-style we want to use.
  To address another idea you mentioned you did.  We too had an idea to create a family of wall styles (many, many different walls) with all the different wall-types that we build; each having their own structure assigned as per material used).  You mentioned creating a template for your dimension styles (which we would like to do as well) and walls, but I am unsure what you mean by template.  Did you create a family to drop into your project?  Or how did you go about creating the template?  I apologize if this should seem straightforward enough, but outside of tutorials we can find online, we are pretty much stumbling over ourselves trying to learn this.  I really wish we would get a consultant to come in for a few days and teach us every aspect we want to be able to use, but alas my company will not do so.   I really feel we are creating too much work for ourselves and not learning efficiently how to actually use the program.
  This is definitely a Page I am going to file for our reference!  You have been very insightful and I have found your advice helpful thus far.
Installation Of Revit Architecture 2009
Mon, May 5, 2008 at 1:59:54 AM
Door naming convention
Mon, Mar 17, 2008 at 4:14:49 PM
Revit Architecture 2009 -- Roof Verge
Sat, Sep 10, 2011 at 10:29:06 AM
Wall Type Tag Labeling Convention
Thu, Sep 25, 2008 at 9:24:51 AM
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Page generation time: 1.8766
