Forums >> Revit Building >> Technical Support >> column to wall connection
Thu, Apr 7, 2011 at 7:45:32 PM | column to wall connection
#16
mcantwell
mcantwell Avatar
Probably revit is based on real world construction so it can have value as a BIM tool
The contractor can't build a structural wall through a structural column on site.
it would also screw up any structural analysis performed by revit or Robot etc
Maybe autocad or paper where they are just lines and hatches would cope.
Thats no help I know, but it might be that Revit is specifically designed not to do the shortcut you want in this instance to maintain the integrity of the structural data.
Fri, Apr 8, 2011 at 6:06:29 AM | column to wall connection
#17
nistorkool
nistorkool Avatar
you may have right. but when i have already the column and I place a wall , the pattern of the column is ok, is not change. well for now i have resolve the problem.
-http://nistor.amsolutions.ro
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 4:40:24 AM
column-beam connection
Tue, Jan 12, 2010 at 5:46:46 AM
Page generation time: 0.5485
